Introduction
Our mighty Indominus Rex is blind! The LEDs in his eyes are not functional. Let's figure out what's going on and fix him up!
Knowing how to solder before attempting this guide is extremely encouraged. Details about soldering technique guide can be found at the last step of this guide.
Ce dont vous avez besoin
Remove the two (2) 7.5mm phillips screws using Phillips #1 screwdriver from the bottom of the jaw.
Remove the two (2) 7.2mm phillips screws using Phillips #0 screwdriver from the bottom of the jaw.
Gently remove the entire bottom jaw piece.
Remove the four (4) 7.5mm Phillips screws from the pieces holding the circuit board for the LEDs in place.
Use tweezers to pull the circuit board out of place.
