Aller au contenu principal
Zoomer Jurassic World Indominus Rex Nose Sensors Replacement
Ce dont vous avez besoin
  1. Zoomer Jurassic World Indominus Rex Nose Sensors Replacement, Mouth Part: étape 1, image 1 de 2 Zoomer Jurassic World Indominus Rex Nose Sensors Replacement, Mouth Part: étape 1, image 2 de 2
    • Flip the toy over to gain direct access to the first screws you need to remove for the replacement.
    • Remove the two (2) 7.5mm phillips screws using Phillips #1 screwdriver from the bottom of the jaw.
    • Remove the two (2) 7.2mm phillips screws using Phillips #0 screwdriver from the bottom of the jaw.
    • Gently remove the entire bottom jaw piece.
  2. Zoomer Jurassic World Indominus Rex Nose Sensors Replacement: étape 2, image 1 de 3 Zoomer Jurassic World Indominus Rex Nose Sensors Replacement: étape 2, image 2 de 3 Zoomer Jurassic World Indominus Rex Nose Sensors Replacement: étape 2, image 3 de 3
    • Remove the 7.5mm phillips screw using Phillips #1 screwdriver from the middle of the tongue.
    • Using a spudger, gently pry the tongue out of the mouth.
  3. Zoomer Jurassic World Indominus Rex Nose Sensors Replacement, Nose Sensors: étape 3, image 1 de 2 Zoomer Jurassic World Indominus Rex Nose Sensors Replacement, Nose Sensors: étape 3, image 2 de 2
    • Carefully, pull out the circuit board that has the three nose sensors attached.
    • You're almost done! The only thing left to do is to use a soldering iron to remove the six (6) wires connected to the circuit board.
    • Use caution when soldering to avoid being burned.
2 autres ont terminé cette réparation.
Luke Selby
Membre depuis le 01/20/16
636 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 10-3, Remmell Spring 2016 Membre de l'équipe USF Tampa, Team 10-3, Remmell Spring 2016
USFT-REMMELL-S16S10G3
4 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 362
