Aller au contenu principal
Zoomer Meowzies Legs Replacement
Ce dont vous avez besoin
  1. Zoomer Meowzies  Legs Replacement, Legs: étape 1, image 1 de 3 Zoomer Meowzies  Legs Replacement, Legs: étape 1, image 2 de 3 Zoomer Meowzies  Legs Replacement, Legs: étape 1, image 3 de 3
    • Using the Triangle driver remove the four 7.5 mm screws.
    • The two front screws are deeper than the two on the back legs which may cause difficulties. These can be reached by putting the bit in first then carefully putting the driver on slightly (not all the way)
  2. Zoomer Meowzies  Legs Replacement: étape 2, image 1 de 2 Zoomer Meowzies  Legs Replacement: étape 2, image 2 de 2
    • Turn the device so that the the device is on its side.
    • Hold the back and belly on the device and gently pull apart.
    • Pulling with too much force might damage a few cables inside, so caution is needed.
  3. Zoomer Meowzies  Legs Replacement: étape 3, image 1 de 3 Zoomer Meowzies  Legs Replacement: étape 3, image 2 de 3 Zoomer Meowzies  Legs Replacement: étape 3, image 3 de 3
    • With insides exposed, grab leg and gently pull up and away from the body to detach them. Repeat for all legs needed.
Muataz Alahmadi
Membre depuis le 02/14/18
193 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S6-G2, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S6-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S6G2
3 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 218
