Introduction
The button on the device's back may sometimes become damaged or dirty and therefore need replacement. This guide will go over how to access the back button's contact in order to clean or replace.
Using the Triangle driver remove the four 7.5 mm screws.
  • Using the Triangle driver remove the four 7.5 mm screws.
  • The two front screws are deeper than the two on the back legs which may cause difficulties. These can be reached by putting the bit in first then carefully putting the driver on slightly (not all the way)
Ajouter un commentaire
Turn the device so that the the device is on its side.
  • Turn the device so that the the device is on its side.
  • Hold the back and belly on the device and gently pull apart.
  • Pulling with too much force might damage a few cables inside, so caution is needed.
  • With insides exposed, grab leg and gently pull up and away from the body to detach them. Repeat for all legs needed.
  • Locate the gray rubber contact in the middle of the bottom half of the device. Using the spudger, lift one corner of the contact until it pops loose.
  • Grab the contact and gently pull until the other side detaches.
  • When replacing the contact pad, use the narrow leads on the pad to pull it into place by twisting around the tips of the tweezers.
Mitchell Gentry
Membre depuis le 14/02/2018
651 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S6-G2, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S6-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S6G2
3 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 27
