Introduction
This guide is a step by step process on how to replace a broken/damaged spring in either the left or right back legs. In order to access the leg components the main chassis and the rear of the pony must be disassembled first.
Ce dont vous avez besoin
Flip the pony over.
Remove the five Triangle 3 screws from underneath.
Remove the black bar by unscrewing the two triangle screws marked in yellow. These screws are recessed into the black bar so you may need an extender for your triangle bit.
Remove all five triangular screws located on the backside of the leg.
Remove the Phillips head screw holding the white leg bracket.
Detach the plastic mount at the top of the leg by sliding it in a vertical motion from the position shown.
