Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Zotac GTX 1080 Ti Mini Fans Replacement
Ce dont vous avez besoin
  1. Zotac GTX 1080 Ti Mini Fans Replacement, Zotac GTX 1080 Ti Mini Fans: étape 1, image 1 de 2 Zotac GTX 1080 Ti Mini Fans Replacement, Zotac GTX 1080 Ti Mini Fans: étape 1, image 2 de 2
    • Be sure to properly ground yourself with an anti-static wristband before working on the graphics card.
    • Use a Phillips #0 screwdriver to remove the two 4mm screws from the right side of the shroud.
  2. Zotac GTX 1080 Ti Mini Fans Replacement: étape 2, image 1 de 2 Zotac GTX 1080 Ti Mini Fans Replacement: étape 2, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the two 4mm screws from the left side of the shroud.
  3. Zotac GTX 1080 Ti Mini Fans Replacement: étape 3, image 1 de 2 Zotac GTX 1080 Ti Mini Fans Replacement: étape 3, image 2 de 2
    • Look for the fan header located beside the 16-pin power connector.
    • Gently pry the fan connector apart from the header with a flathead screwdriver.
  4. Zotac GTX 1080 Ti Mini Fans Replacement: étape 4, image 1 de 2 Zotac GTX 1080 Ti Mini Fans Replacement: étape 4, image 2 de 2
    • Slowly and carefully lift the shroud off the heatsink.
    • During this step, make sure not to damage the LED connector that is still connecting the shroud to the PCB.
    • Flip the shroud along the top of the graphics card.
  5. Zotac GTX 1080 Ti Mini Fans Replacement: étape 5, image 1 de 3 Zotac GTX 1080 Ti Mini Fans Replacement: étape 5, image 2 de 3 Zotac GTX 1080 Ti Mini Fans Replacement: étape 5, image 3 de 3
    • Remove the three 3 mm Phillips screws holding the fans to the heatsink with a Phillips #0 screwdriver.
    • Remove the broken fans.
  6. Zotac GTX 1080 Ti Mini Fans Replacement: étape 6, image 1 de 3 Zotac GTX 1080 Ti Mini Fans Replacement: étape 6, image 2 de 3 Zotac GTX 1080 Ti Mini Fans Replacement: étape 6, image 3 de 3
    • Place the replacement fan on top of the heatsink with the screw holes aligned.
    • Screw the fans into place using a Phillips #0 screwdriver.
  7. Zotac GTX 1080 Ti Mini Fans Replacement: étape 7, image 1 de 1
    • Reconnect the fan connector to its header.
  8. Zotac GTX 1080 Ti Mini Fans Replacement: étape 8, image 1 de 3 Zotac GTX 1080 Ti Mini Fans Replacement: étape 8, image 2 de 3 Zotac GTX 1080 Ti Mini Fans Replacement: étape 8, image 3 de 3
    • Place the shroud back over the heatsink and screw it back into place using a Phillips #0 screwdriver.
Hopefully, your graphics card is fully replaced and completely working now.
Victor Pan
Membre depuis le 01/27/21
175 Réputation
1 tutoriel rédigé
Équipe
York University, Team S16-G7, Turner Winter 2021 Membre de l'équipe York University, Team S16-G7, Turner Winter 2021
YORK-TURNER-W21S16G7
3 membres
2 tutoriels rédigés
1 commentaire de tutoriel
Do you know what size (diameter and thread) the 4mm and 3mm screws are?
cchagadorn - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 26
30 derniers jours : 134
Total : 7,380
