Introduction
This will serve as a guide for the replacement of a Zune Flash 2nd Generation battery and memory board.
Pièces
Aucune pièce spécifiée.
Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
If the device turns on while it is being disassembled it could cause irreversible damage to the device.
Remove the three screws (5.5mm by 3mm) from the backside of the Zune using a small Tri-Wing screwdriver.
Be sure to put this set of screws aside since they are a different size than any other screws in the device.
Release the LCD connector ribbon by flipping up the black switch. This will disconnect the LCD from the device.
At this point the LCD screen should be easily separable from the device.
Detaching the memory board from the battery requires desoldering the 4 joints on the memory board.
It will be easiest to go in the order blue, yellow, black, red.
2 autre(s) ont terminé cette réparation.
Un commentaire
Guide doesn’t mention that the display ribbon is sometimes held down by adhesive near the connector
