Aller au contenu principal
Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement
Ce dont vous avez besoin
  1. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement, Heater: étape 1, image 1 de 2 Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement, Heater: étape 1, image 2 de 2
    • Disconnect the power plug located on the back of the massage pillow.
    • Please do this step carefully in order to avoid electric shock.
  2. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: étape 2, image 1 de 2 Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: étape 2, image 2 de 2
    • Unzip the cover. You can locate the zipper at the back of the massage pillow.
    • Take out the pillow so that you can manage the heater completely.
  3. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: étape 3, image 1 de 1
    • Use a Phillips JIS #1 screwdriver to remove the screw at the center of the heater.
    • The screw is 8.0mm.
  4. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: étape 4, image 1 de 2 Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: étape 4, image 2 de 2
    • Remove the entire heater from the pillow.
    • You can see a green circuit board after removing the heater.
  5. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: étape 5, image 1 de 1
    • Using the Phillips JIS #1 screwdriver, remove the three screws circled in the picture.
    • All three screws are 8.0mm, which are the same size as the previous one. They are interchangeable.
  6. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: étape 6, image 1 de 1
    • Now you can take out the circuit board. There will be two wires attached to the circuit board.
    • If you prefer, you can clean the circuit board gently with dry tissues to remove the sticky lubricant.
  7. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: étape 7, image 1 de 1
    • Use the pry bar to separate the wire from the white main board.
    • Before prying, check if you removed the power plug from the outlet and the massage pillow.
  8. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: étape 8, image 1 de 1
    • Using your soldering station, remove the wires from the circuit board.
    • If you don't know how to solder, you can check out this guide: How To Solder and Desolder Connections
    • Soldering can be dangerous. Be cautious of high heat soldering tools.
    • Now, you can separate the circuit board completely to replace with a new heater.
Yuchen Li
Membre depuis le 09/28/15
125 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 14-2, Green Fall 2015 Membre de l'équipe Cal Poly, Team 14-2, Green Fall 2015
CPSU-GREEN-F15S14G2
4 membres
8 tutoriels rédigés
2 commentaires
Hi YuChen, nice work! Do you know from where I can find the switch for this heater? If you can tell me the part number, I can try looking it up on eBay. Thanks!
Abhishek Srivastava - Réponse
YuChen, by any chance do you know where I can get the whole covering of this Shiatsu Massage Pillow. The fabric of mine has deteriorated and torn off. I have been trying to find one using Google search but was unable to find. Can you help, Thank you
gamesake2 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 55
Total : 6,007
