Aller au contenu principal
bObi Pet UV Lamp Replacement
Ce dont vous avez besoin
  1. bObi Pet UV Lamp Replacement, Turn bObi Pet Off: étape 1, image 1 de 3 bObi Pet UV Lamp Replacement, Turn bObi Pet Off: étape 1, image 2 de 3 bObi Pet UV Lamp Replacement, Turn bObi Pet Off: étape 1, image 3 de 3
    • Before we get started, turn bObi Pet OFF and flip her over onto a flat surface.
    • Next, remove bObi Pet's dustbin. Grip the small tab on the back of the bin, and pull to remove.
  2. bObi Pet UV Lamp Replacement, Remove the Front Wheel: étape 2, image 1 de 2 bObi Pet UV Lamp Replacement, Remove the Front Wheel: étape 2, image 2 de 2
    • Grip the front wheel and pull straight up, using the screwdriver for leverage.
    • The wheel will pop out and you will see two screws beneath it.
    • There is a larger screw set deeper in the wheel compartment. Use the screwdriver to remove it.
    • Remember to keep all screws and parts removed from bObi Pet safely aside during the repair. They may be needed for re-assembly.
  3. bObi Pet UV Lamp Replacement, Remove the Dustbin's Holders: étape 3, image 1 de 3 bObi Pet UV Lamp Replacement, Remove the Dustbin's Holders: étape 3, image 2 de 3 bObi Pet UV Lamp Replacement, Remove the Dustbin's Holders: étape 3, image 3 de 3
    • Remove the screws on both sides of bObi Pet’s dustbin. Then, remove the corner pieces that were held down by the screws.
    • Grip the brush compartment and pull down to reveal two screws on a red fastener.
    • Remove them with the screwdriver.
  4. bObi Pet UV Lamp Replacement, Remove the Main Brush Attachment: étape 4, image 1 de 3 bObi Pet UV Lamp Replacement, Remove the Main Brush Attachment: étape 4, image 2 de 3 bObi Pet UV Lamp Replacement, Remove the Main Brush Attachment: étape 4, image 3 de 3
    • Pull the brush compartment up until the fastener is freed from bObi Pet. Then, detach the brush compartment's circuit plug and set it aside.
    • Remove the 4 screws located beneath the brush compartment.
  5. bObi Pet UV Lamp Replacement, Remove the Cover Screws: étape 5, image 1 de 2 bObi Pet UV Lamp Replacement, Remove the Cover Screws: étape 5, image 2 de 2
    • Remove the 2 screws on the dustbin’s red fastener.
    • Remove the fastener and set it aside for reassembly.
    • The cover is no longer secured, so carefully flip bObi Pet onto her wheels.
  6. bObi Pet UV Lamp Replacement, Detach the Cover: étape 6, image 1 de 3 bObi Pet UV Lamp Replacement, Detach the Cover: étape 6, image 2 de 3 bObi Pet UV Lamp Replacement, Detach the Cover: étape 6, image 3 de 3
    • Lift the cover to reveal the main board underneath.
    • Remove the two circuit plugs connecting the lid to the mainboard.
    • bObi Pet's cover is entirely separated, and you may now access any of her internal parts for replacement.
  7. bObi Pet UV Lamp Replacement, Unplug the Lamp: étape 7, image 1 de 2 bObi Pet UV Lamp Replacement, Unplug the Lamp: étape 7, image 2 de 2
    • The UV lamp connects to bObi Pet’s left side.
    • Remove the small, red-and-black-wired circuit plug, and break off any glue holding it in place.
  8. bObi Pet UV Lamp Replacement, Remove the Circuit Board Cover: étape 8, image 1 de 3 bObi Pet UV Lamp Replacement, Remove the Circuit Board Cover: étape 8, image 2 de 3 bObi Pet UV Lamp Replacement, Remove the Circuit Board Cover: étape 8, image 3 de 3
    • Remove the 2 screws on the black circuit cover.
    • Lift the black cover up to expose the small circuit board for bObi Pet’s UV lamp.
    • Then, slide the circuit board up to remove.
  9. bObi Pet UV Lamp Replacement, Remove the Lamp: étape 9, image 1 de 3 bObi Pet UV Lamp Replacement, Remove the Lamp: étape 9, image 2 de 3 bObi Pet UV Lamp Replacement, Remove the Lamp: étape 9, image 3 de 3
    • Next, remove the 2 screws on the UV lamp.
    • Gently push the UV lamp out of its spot from underneath.
    • Then, lift out the whole lamp, including the cover plate.
  10. bObi Pet UV Lamp Replacement, Place the New UV Lamp: étape 10, image 1 de 3 bObi Pet UV Lamp Replacement, Place the New UV Lamp: étape 10, image 2 de 3 bObi Pet UV Lamp Replacement, Place the New UV Lamp: étape 10, image 3 de 3
    • Lay the replacement lamp in the empty space. Place the cover plate in first, then the lightbulb on top.
    • Once the lamp lies flat, install its 2 screws.
  11. bObi Pet UV Lamp Replacement, Replace the Circuit Board Cover: étape 11, image 1 de 3 bObi Pet UV Lamp Replacement, Replace the Circuit Board Cover: étape 11, image 2 de 3 bObi Pet UV Lamp Replacement, Replace the Circuit Board Cover: étape 11, image 3 de 3
    • Slide the new circuit board down into its holder and replace the black cover.
    • Be sure to tuck the lamp’s wires through the indentations at the bottom of the cover before installing its 2 screws.
  12. bObi Pet UV Lamp Replacement: étape 12, image 1 de 2 bObi Pet UV Lamp Replacement: étape 12, image 2 de 2
    • Attach the lamp's circuit plug to the main board and you'll be ready to close bObi Pet's cover.
    • See this guide for help re-assembling bObi Pet: Assemble bObi Pet Post-Repair
To put bObi Pet back together, refer to this guide: Assemble bObi Pet Post-Repair
Chelsea
Membre depuis le 09/24/14
2 278 Réputation
31 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 8
Total : 115
