Aller au contenu principal
bObi Robotic Vacuum Left or Right Wheel Replacement
Ce dont vous avez besoin
  1. bObi Robotic Vacuum Left or Right Wheel Replacement, Top Cover: étape 1, image 1 de 2 bObi Robotic Vacuum Left or Right Wheel Replacement, Top Cover: étape 1, image 2 de 2
    • Remove bObi’s front wheel to access one of the screws holding bObi together.
    • Make sure the wheel is turned closer to bObi's front touch sensors. Use your screwdriver for leverage, and the wheel will pop up and out.
    • Uninstall the larger screw that sits deeper in the wheel compartment.
  2. bObi Robotic Vacuum Left or Right Wheel Replacement: étape 2, image 1 de 3 bObi Robotic Vacuum Left or Right Wheel Replacement: étape 2, image 2 de 3 bObi Robotic Vacuum Left or Right Wheel Replacement: étape 2, image 3 de 3
    • Remove bObi's dustbin.
    • Uninstall the 2 screws close to the bin and 2 smaller screws above her main brushes.
  3. bObi Robotic Vacuum Left or Right Wheel Replacement: étape 3, image 1 de 3 bObi Robotic Vacuum Left or Right Wheel Replacement: étape 3, image 2 de 3 bObi Robotic Vacuum Left or Right Wheel Replacement: étape 3, image 3 de 3
    • Lift the brush holder. To detach completely, unplug it from bObi.
    • Remove the two screws on the dustbin contact point holder inside bObi.
    • There are 4 screws beneath the main brushes. Uninstall these, and open bObi up to expose her main circuit board.
  4. bObi Robotic Vacuum Left or Right Wheel Replacement: étape 4, image 1 de 3 bObi Robotic Vacuum Left or Right Wheel Replacement: étape 4, image 2 de 3 bObi Robotic Vacuum Left or Right Wheel Replacement: étape 4, image 3 de 3
    • Detach the two circuit plugs connecting bObi's cover to the main board and the cover will be completely removed.
  5. bObi Robotic Vacuum Left or Right Wheel Replacement, Left or Right Wheel: étape 5, image 1 de 3 bObi Robotic Vacuum Left or Right Wheel Replacement, Left or Right Wheel: étape 5, image 2 de 3 bObi Robotic Vacuum Left or Right Wheel Replacement, Left or Right Wheel: étape 5, image 3 de 3
    • The left and right wheels are held on bObi with two screws. Uninstall them from the wheel you’re replacing, and flip bObi over.
  6. bObi Robotic Vacuum Left or Right Wheel Replacement: étape 6, image 1 de 3 bObi Robotic Vacuum Left or Right Wheel Replacement: étape 6, image 2 de 3 bObi Robotic Vacuum Left or Right Wheel Replacement: étape 6, image 3 de 3
    • The left and right wheels attach near the front of the main board. Remove the circuit plug for the wheel you wish to replace. If there is glue on the plug, simply peel it off.
    • Lift bObi up slightly, and feed the wheel’s wiring out of the open space so the whole wheel detaches.
  7. bObi Robotic Vacuum Left or Right Wheel Replacement: étape 7, image 1 de 3 bObi Robotic Vacuum Left or Right Wheel Replacement: étape 7, image 2 de 3 bObi Robotic Vacuum Left or Right Wheel Replacement: étape 7, image 3 de 3
    • Place the new wheel in the open space. Make sure its circuit plug goes through and reaches bObi’s interior. Then plug it in on the mainboard.
    • You may add glue or electrical tape to secure the wires on the inside of bObi.
  8. bObi Robotic Vacuum Left or Right Wheel Replacement: étape 8, image 1 de 2 bObi Robotic Vacuum Left or Right Wheel Replacement: étape 8, image 2 de 2
To put bObi's cover back together, refer to the Closing bObi's Cover Post-Repair guide.
Chelsea
Membre depuis le 09/24/14
2 278 Réputation
31 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 654
