Introduction
For assistance putting bObi back together, follow the guide on closing bObi: Closing bObi's Cover Post-Repair
Outils
Aucun outil requis.
Pièces
Aucune pièce nécessaire.
Remove bObi’s front wheel to access one of the screws holding bObi together.
  • Remove bObi’s front wheel to access one of the screws holding bObi together.
  • Make sure the wheel is turned closer to bObi's front touch sensors. Use your screwdriver for leverage, and the wheel will pop up and out.
  • Uninstall the larger screw that sits deeper in the wheel compartment.
Ajouter un commentaire
Remove bObi's dustbin.
  • Remove bObi's dustbin.
  • Uninstall the 2 screws close to the bin and 2 smaller screws above her main brushes.
  • Lift the brush holder. To detach completely, unplug it from bObi.
  • Remove the two screws on the dustbin contact point holder inside bObi.
  • There are 4 screws beneath the main brushes. Uninstall these, and open bObi up to expose her main circuit board.
  • Detach the two circuit plugs connecting bObi's cover to the main board and the cover will be completely removed.
  • All of bObi’s wall detection sensors are plugged in to a small circuit board on the underside of the cover.
  • Refer to bObi’s check up test in order to determine which sensor is in need of repair. Then, remove the two screws holding it on the front bumper.
  • You will be able to push the sensor from the inside of the cover, so it pops out of its place on the bumper.
  • Unplug the appropriate circuit plug from the cover's circuit board.
  • Unhook the wires from the holders on the inside of the bumper.
  • Feed the circuit plug and its wires through the open space in bObi’s bumper.
  • Put the circuit plug for your replacement part through the obstacle detection sensor’s open slot.
  • Place the actual sensor in its space on the bumper and install the two screws which secure it to bObi.
  • Feed the wires for the sensor's circuit plug back through the hooks on bObi's bumper.
  • Then, plug it into the empty spot on bObi’s cover circuit board.
  • To finish off this repair, follow the closing bObi manual: Closing bObi's Cover Post-Repair
To reassemble bObi, refer to the Closing bObi Guide.
Chelsea
Membre depuis le 24/09/2014
2 278 Réputation
31 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 224
