Aller au contenu principal
bObsweep PetHair Plus WPP56002 Brush Motor Replacement
Ce dont vous avez besoin
  1. bObsweep PetHair Plus WPP56002 Brush Motor Replacement, Cover: étape 1, image 1 de 1
    • Depress the tab on the side of the dustbin to disengage its latch. It is spring loaded and will partially pop out. Remove it from its housing.
  2. bObsweep PetHair Plus WPP56002 Brush Motor Replacement: étape 2, image 1 de 3 bObsweep PetHair Plus WPP56002 Brush Motor Replacement: étape 2, image 2 de 3 bObsweep PetHair Plus WPP56002 Brush Motor Replacement: étape 2, image 3 de 3
    • Flip the bObsweep over and remove the main brush’s screw (13.7mm Flat) with a flathead screwdriver.
    • Lift and remove the main brush and its plastic bearing end cap.
  3. bObsweep PetHair Plus WPP56002 Brush Motor Replacement: étape 3, image 1 de 2 bObsweep PetHair Plus WPP56002 Brush Motor Replacement: étape 3, image 2 de 2
    • Remove the two screws (9.9mm Phillips #1) next to the rotating front wheel.
    • Remove the two screws (9.9mm Phillips #1) below the wheels on either side of the dustbin compartment.
    • Remove the screw (9.9mm Phillips #1) to the side of the brush motor.
    • Remove the screw (9.9mm Phillips #1) inside the brush compartment.
  4. bObsweep PetHair Plus WPP56002 Brush Motor Replacement: étape 4, image 1 de 2 bObsweep PetHair Plus WPP56002 Brush Motor Replacement: étape 4, image 2 de 2
    • Carefully hold the top and bottom halves together and flip the bObsweep upright.
    • Lift the cover to reveal the mainboard.
  5. bObsweep PetHair Plus WPP56002 Brush Motor Replacement: étape 5, image 1 de 3 bObsweep PetHair Plus WPP56002 Brush Motor Replacement: étape 5, image 2 de 3 bObsweep PetHair Plus WPP56002 Brush Motor Replacement: étape 5, image 3 de 3
    • Slide the power inlet down.
    • Tuck it aside to protect it from damage.
  6. bObsweep PetHair Plus WPP56002 Brush Motor Replacement: étape 6, image 1 de 3 bObsweep PetHair Plus WPP56002 Brush Motor Replacement: étape 6, image 2 de 3 bObsweep PetHair Plus WPP56002 Brush Motor Replacement: étape 6, image 3 de 3
    • Depress the tabs on the circuit plugs and lift them directly upward to remove:
    • The multicolored nine-wire circuit plug at the top edge of the board.
    • The red and black wire circuit plug directly next to it.
    • The seven white wire circuit plug on the bottom edge of the board.
    • The red, white, and black wire circuit plug on the bottom left corner of the board.
  7. bObsweep PetHair Plus WPP56002 Brush Motor Replacement, Brush Motor: étape 7, image 1 de 2 bObsweep PetHair Plus WPP56002 Brush Motor Replacement, Brush Motor: étape 7, image 2 de 2
    • Slide the main brush motor up and out of its housing. (located in front of the wheel on the left side)
  8. bObsweep PetHair Plus WPP56002 Brush Motor Replacement: étape 8, image 1 de 1
    • Grip the circuit plug tab and pull up to disconnect it from the mainboard.
  9. bObsweep PetHair Plus WPP56002 Brush Motor Replacement: étape 9, image 1 de 1
    • Insert the circuit plug of the new motor into the mainboard.
  10. bObsweep PetHair Plus WPP56002 Brush Motor Replacement: étape 10, image 1 de 2 bObsweep PetHair Plus WPP56002 Brush Motor Replacement: étape 10, image 2 de 2
    • Align the edges of the motor with the internal indentations for it and slide it straight down into place.
Saylor Price
Membre depuis le 09/07/23
957 Réputation
7 tutoriels rédigés
Équipe
University of Memphis, Team 1-3, Sneed Fall 2023 Membre de l'équipe University of Memphis, Team 1-3, Sneed Fall 2023
UM-SNEED-F23S1G3
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 74
