Aller au contenu principal
bObsweep PetHair Plus WPP56002 Wheel Motor Replacement
Ce dont vous avez besoin
  1. bObsweep PetHair Plus WPP56002 Wheel Motor Replacement, Cover: étape 1, image 1 de 1
    • Depress the tab on the side of the dustbin to disengage its latch. It is spring loaded and will partially pop out. Remove it from its housing.
  2. bObsweep PetHair Plus WPP56002 Wheel Motor Replacement: étape 2, image 1 de 3 bObsweep PetHair Plus WPP56002 Wheel Motor Replacement: étape 2, image 2 de 3 bObsweep PetHair Plus WPP56002 Wheel Motor Replacement: étape 2, image 3 de 3
    • Flip the bObsweep over and remove the main brush’s screw (13.7mm Flat) with a flathead screwdriver.
    • Lift and remove the main brush and its plastic bearing end cap.
  3. bObsweep PetHair Plus WPP56002 Wheel Motor Replacement: étape 3, image 1 de 2 bObsweep PetHair Plus WPP56002 Wheel Motor Replacement: étape 3, image 2 de 2
    • Remove the two screws (9.9mm Phillips #1) next to the rotating front wheel.
    • Remove the two screws (9.9mm Phillips #1) below the wheels on either side of the dustbin compartment.
    • Remove the screw (9.9mm Phillips #1) to the side of the brush motor.
    • Remove the screw (9.9mm Phillips #1) inside the brush compartment.
  4. bObsweep PetHair Plus WPP56002 Wheel Motor Replacement: étape 4, image 1 de 2 bObsweep PetHair Plus WPP56002 Wheel Motor Replacement: étape 4, image 2 de 2
    • Carefully hold the top and bottom halves together and flip the bObsweep upright.
    • Lift the cover to reveal the mainboard.
  5. bObsweep PetHair Plus WPP56002 Wheel Motor Replacement: étape 5, image 1 de 3 bObsweep PetHair Plus WPP56002 Wheel Motor Replacement: étape 5, image 2 de 3 bObsweep PetHair Plus WPP56002 Wheel Motor Replacement: étape 5, image 3 de 3
    • Slide the power inlet down.
    • Tuck it aside to protect it from damage.
  6. bObsweep PetHair Plus WPP56002 Wheel Motor Replacement: étape 6, image 1 de 3 bObsweep PetHair Plus WPP56002 Wheel Motor Replacement: étape 6, image 2 de 3 bObsweep PetHair Plus WPP56002 Wheel Motor Replacement: étape 6, image 3 de 3
    • Depress the tabs on the circuit plugs and lift them directly upward to remove:
    • The multicolored nine-wire circuit plug at the top edge of the board.
    • The red and black wire circuit plug directly next to it.
    • The seven white wire circuit plug on the bottom edge of the board.
    • The red, white, and black wire circuit plug on the bottom left corner of the board.
  7. bObsweep PetHair Plus WPP56002 Wheel Motor Replacement, Wheel Motor: étape 7, image 1 de 3 bObsweep PetHair Plus WPP56002 Wheel Motor Replacement, Wheel Motor: étape 7, image 2 de 3 bObsweep PetHair Plus WPP56002 Wheel Motor Replacement, Wheel Motor: étape 7, image 3 de 3
    • Unscrew the six screws (9.9 mm Phillips #1) securing the wheel cover.
    • The main brush motor and power switch may need to be moved to access these securing screws.
    • Remove the wheel cover from the mainboard.
  8. bObsweep PetHair Plus WPP56002 Wheel Motor Replacement: étape 8, image 1 de 1
    • Remove the wheel springs and set them aside so they are not misplaced.
  9. bObsweep PetHair Plus WPP56002 Wheel Motor Replacement: étape 9, image 1 de 2 bObsweep PetHair Plus WPP56002 Wheel Motor Replacement: étape 9, image 2 de 2
    • Extract the malfunctioning wheel.
    • Unplug the wheel from the mainboard.
  10. bObsweep PetHair Plus WPP56002 Wheel Motor Replacement: étape 10, image 1 de 1
    • Prop up bObsweep’s back a few inches.
    • Install the new wheel.
  11. bObsweep PetHair Plus WPP56002 Wheel Motor Replacement: étape 11, image 1 de 2 bObsweep PetHair Plus WPP56002 Wheel Motor Replacement: étape 11, image 2 de 2
    • Plug the left wheel into the mainboard.
    • Feed the wires around the bottom edge so they do not become stuck under the main brush motor.
    • Plug the right wheel into the mainboard.
    • Feed the wires around the closest screw post under the mainboard and pull them back out.
Saylor Price
Membre depuis le 09/07/23
957 Réputation
7 tutoriels rédigés
Équipe
University of Memphis, Team 1-3, Sneed Fall 2023 Membre de l'équipe University of Memphis, Team 1-3, Sneed Fall 2023
UM-SNEED-F23S1G3
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 65
