Aller au contenu principal
bObsweep Robotic Vacuum Battery Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. bObsweep Robotic Vacuum Battery Replacement, Battery: étape 1, image 1 de 3 bObsweep Robotic Vacuum Battery Replacement, Battery: étape 1, image 2 de 3 bObsweep Robotic Vacuum Battery Replacement, Battery: étape 1, image 3 de 3
    • Unscrew the battery's cover plate on bObsweep's underside, above the main brush.
    • Lift the cover plate to expose the battery.
  2. bObsweep Robotic Vacuum Battery Replacement: étape 2, image 1 de 3 bObsweep Robotic Vacuum Battery Replacement: étape 2, image 2 de 3 bObsweep Robotic Vacuum Battery Replacement: étape 2, image 3 de 3
    • Lift the battery up and out of its compartment.
    • Using both hands, pinch the plastic connector where the battery's wiring attaches to bObsweep and pull apart to disconnect.
  3. bObsweep Robotic Vacuum Battery Replacement: étape 3, image 1 de 3 bObsweep Robotic Vacuum Battery Replacement: étape 3, image 2 de 3 bObsweep Robotic Vacuum Battery Replacement: étape 3, image 3 de 3
    • Connect the wires of the new battery. Push together tightly and it will lock in place.
    • Tuck the wires down inside the battery compartment on the right side.
    • Lower the battery down into bObsweep with the barcode facing up.
  4. bObsweep Robotic Vacuum Battery Replacement: étape 4, image 1 de 3 bObsweep Robotic Vacuum Battery Replacement: étape 4, image 2 de 3 bObsweep Robotic Vacuum Battery Replacement: étape 4, image 3 de 3
    • Lower the cover down so it lies flat and the screw holes of the cover line up with those on bObsweep.
    • Reinstall the two screws removed in step one to secure the cover and battery in place.
A quick fix for bObsweep's power supply. Changing an old lithium ion battery for a new one ensures the vacuum will work longer with fewer charging breaks.
Tatiana
Membre depuis le 06/28/14
737 Réputation
17 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 23
Total : 2,790
