Aller au contenu principal
d.light Solar Lantern S2 Battery Replacement
Ce dont vous avez besoin
  1. d.light Solar Lantern S2 Battery Replacement, Battery: étape 1, image 1 de 2 d.light Solar Lantern S2 Battery Replacement, Battery: étape 1, image 2 de 2
    • To remove the lens, three T15 x 12.5mm screws must be removed by a T15 head screwdriver.
    • The location of the other two screws are marked in red.
  2. d.light Solar Lantern S2 Battery Replacement: étape 2, image 1 de 3 d.light Solar Lantern S2 Battery Replacement: étape 2, image 2 de 3 d.light Solar Lantern S2 Battery Replacement: étape 2, image 3 de 3
    • After the lens has been removed the back cover needs to be removed. There are no snaps or screws holding it in place.
  3. d.light Solar Lantern S2 Battery Replacement: étape 3, image 1 de 3 d.light Solar Lantern S2 Battery Replacement: étape 3, image 2 de 3 d.light Solar Lantern S2 Battery Replacement: étape 3, image 3 de 3
    • Take the battery out of its setting. It is only held in by friction (no snaps or screws).
    • Disconnect the battery by unpluging the white connector.
    • Install the new battery
4 autres ont terminé cette réparation.
Jeremiah Rhoades
Membre depuis le 11/07/17
435 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S2-G3, Harley Fall 2017 Membre de l'équipe IUPUI, Team S2-G3, Harley Fall 2017
IUPUI-HARLEY-F17S2G3
3 membres
3 tutoriels rédigés
Un commentaire
thanks for this.
You didn’t mention the model/name of the battery replacement. Can you help with that?
Albert H - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 48
Total : 2,160
