Aller au contenu principal
d.light Solar Lantern S2 Solar Panel Replacement
Ce dont vous avez besoin
  1. d.light Solar Lantern S2 Solar Panel Replacement, Solar Panel: étape 1, image 1 de 2 d.light Solar Lantern S2 Solar Panel Replacement, Solar Panel: étape 1, image 2 de 2
    • To remove the lens, three T15 x 12.5mm screws must be removed by a T15 head screwdriver.
    • The location of the other two screws are marked in red.
  2. d.light Solar Lantern S2 Solar Panel Replacement: étape 2, image 1 de 2 d.light Solar Lantern S2 Solar Panel Replacement: étape 2, image 2 de 2
    • After the lens has been removed the back cover needs to be removed. There are no snaps or screws holding it in place.
  3. d.light Solar Lantern S2 Solar Panel Replacement: étape 3, image 1 de 2 d.light Solar Lantern S2 Solar Panel Replacement: étape 3, image 2 de 2
    • Desolder the yellow and black wires that connect the solar panel to the circuit board.
    • Remove the solar panel by pressing on the mounting clips (underneath fingers) using the spudger.
  4. d.light Solar Lantern S2 Solar Panel Replacement: étape 4, image 1 de 2 d.light Solar Lantern S2 Solar Panel Replacement: étape 4, image 2 de 2
    • Solder the wires to the solar panel (positive to positive, negative to negative).
Jeremiah Rhoades
Membre depuis le 11/07/17
435 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S2-G3, Harley Fall 2017 Membre de l'équipe IUPUI, Team S2-G3, Harley Fall 2017
IUPUI-HARLEY-F17S2G3
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 19
Total : 645
