Aller au contenu principal
Ce dont vous avez besoin
  1. dreamGEAR Quad Dock Pro Electrical Port Replacement, Prerequisite Guide to Accessing Interior: étape 1, image 1 de 2 dreamGEAR Quad Dock Pro Electrical Port Replacement, Prerequisite Guide to Accessing Interior: étape 1, image 2 de 2
    • Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
  2. dreamGEAR Quad Dock Pro Electrical Port Replacement: étape 2, image 1 de 2 dreamGEAR Quad Dock Pro Electrical Port Replacement: étape 2, image 2 de 2
    • Remove the six 2 mm PH0 screws on the bottom of the device.
    • Four of those screws are located under the foot pads.
  3. dreamGEAR Quad Dock Pro Electrical Port Replacement: étape 3, image 1 de 1
    • Gently remove the bottom of the device.
  4. dreamGEAR Quad Dock Pro Electrical Port Replacement, Mother Board: étape 4, image 1 de 2 dreamGEAR Quad Dock Pro Electrical Port Replacement, Mother Board: étape 4, image 2 de 2
    • Remove the four 1.8 mm J1 screws.
    • Remove the two 2mm PH0 screws.
  5. dreamGEAR Quad Dock Pro Electrical Port Replacement: étape 5, image 1 de 1
    • Gently pick up the mother board
    • Pick the mother board straight up or you may risk damaging the mini-USB charging ports.
  6. dreamGEAR Quad Dock Pro Electrical Port Replacement: étape 6, image 1 de 2 dreamGEAR Quad Dock Pro Electrical Port Replacement: étape 6, image 2 de 2
    • Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
  7. dreamGEAR Quad Dock Pro Electrical Port Replacement, Electrical Port: étape 7, image 1 de 3 dreamGEAR Quad Dock Pro Electrical Port Replacement, Electrical Port: étape 7, image 2 de 3 dreamGEAR Quad Dock Pro Electrical Port Replacement, Electrical Port: étape 7, image 3 de 3
    • Locate the three solder connections for the electrical port.
    • Desolder the connection points following the instructions included with your soldering kit as you remove the port.
    • FIRE HAZARD! BURN DANGER! Follow all the safety precautions included with your soldering kit.
    • It is helpful to use a nylon or metal spudger or tweezers for the removal of this component, pieces of which are very hot.
    • You can follow iFixit's guide to soldering here.
Jacob
Membre depuis le 11/03/2015
750 Réputation
6 tutoriels rédigés
Équipe
Colorado Springs, Team 4-4, Panko Spring 2015 Membre de l'équipe Colorado Springs, Team 4-4, Panko Spring 2015
UCCS-PANKO-S15S4G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 243
