Aller au contenu principal
dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement
Ce dont vous avez besoin
  1. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Prerequisite Guide to Accessing Interior: étape 1, image 1 de 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Prerequisite Guide to Accessing Interior: étape 1, image 2 de 2
    • Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
  2. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: étape 2, image 1 de 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: étape 2, image 2 de 2
    • Remove the six 2 mm PH0 screws on the bottom of the device.
    • Four of those screws are located under the foot pads.
  3. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: étape 3, image 1 de 1
    • Gently remove the bottom of the device.
  4. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Mother Board: étape 4, image 1 de 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Mother Board: étape 4, image 2 de 2
    • Remove the four 1.8 mm J1 screws.
    • Remove the two 2mm PH0 screws.
  5. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: étape 5, image 1 de 1
    • Gently pick up the mother board
    • Pick the mother board straight up or you may risk damaging the mini-USB charging ports.
  6. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: étape 6, image 1 de 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: étape 6, image 2 de 2
    • Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
  7. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Power Board: étape 7, image 1 de 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Power Board: étape 7, image 2 de 2
    • Remove the four 1.8 mm PH0 screws that are holding the board in.
    • When you remove these screws, the plastic cups inside the PS Move stations will fall out.
  8. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: étape 8, image 1 de 1
    • Pick up the board.
    • Pick the board straight up, or you risk damaging the charging ports.
  9. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: étape 9, image 1 de 1
    • Using a plastic opening tool or a similar tool, gently pry the power ribbon cord out of its port.
Jacob
Membre depuis le 03/11/15
757 Réputation
6 tutoriels rédigés
Équipe
Colorado Springs, Team 4-4, Panko Spring 2015 Membre de l'équipe Colorado Springs, Team 4-4, Panko Spring 2015
UCCS-PANKO-S15S4G4
3 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 196
