Aller au contenu principal
eMac AirPort Card Replacement
Ce dont vous avez besoin
  1. eMac AirPort Card Replacement, AirPort Card: étape 1, image 1 de 1
    • Installation of the AirPort Card on this machine is very easy.
    • The AirPort slot is located just above the Optical Drive in the front of the unit. It is covered by a small plastic panel.
  2. eMac AirPort Card Replacement: étape 2, image 1 de 2 eMac AirPort Card Replacement: étape 2, image 2 de 2
    • Press the eject arrow located on the upper right corner of your keyboard. Once the optical drive tray is open, gently hold it and shut down the machine.
    • Remove the two Phillips screws located to the right and left sides of the optical drive tray.
    • The Airport cable is snapped into place on the back of the optical drive panel .
    • Gently remove the panel from the front of the eMac
    • Disconnect the AirPort cable from the optical drive panel.
    • Pull the AirPort card straight away from its socket in the eMac.
  3. eMac AirPort Card Replacement: étape 3, image 1 de 2 eMac AirPort Card Replacement: étape 3, image 2 de 2
    • Slide the new AirPort card into the slot until its firmly seated.
    • Reconnect the AirPort cable to the optical drive panel.
    • Reattach the optical drive panel and restart the eMac.
    • To configure the AirPort card, go under the Apple in the upper left hand corner to System Preferences - Network. The AirPort option should be on the left hand window. Select it.
    • It should set up on its own. If not hit the "Assist Me" box on the bottom of the page.
19 autres ont terminé cette réparation.
mayer
Membre depuis le 01/04/10
685 316 Réputation
12 tutoriels rédigés
Équipe
MacHale Enterprises Membre de l'équipe MacHale Enterprises
Business
1 membre
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 13
30 derniers jours : 53
Total : 26,768
