Aller au contenu principal
enTourage Pocket eDGe Battery Replacement
Ce dont vous avez besoin
  1. enTourage Pocket eDGe Battery Replacement, Battery: étape 1, image 1 de 3 enTourage Pocket eDGe Battery Replacement, Battery: étape 1, image 2 de 3 enTourage Pocket eDGe Battery Replacement, Battery: étape 1, image 3 de 3
    • Make sure the device is powered off before beginning.
    • Open the Pocket Edge and place device with the screens face down. The side containing the stylus should be on the left.
    • Remove all eight elliptical rubber tabs covering screws using your finger or spudger.
  2. enTourage Pocket eDGe Battery Replacement: étape 2, image 1 de 1
    • Using your J1 Phillips head screwdriver, remove all eight 6mm screws from the back of your device.
  3. enTourage Pocket eDGe Battery Replacement: étape 3, image 1 de 3 enTourage Pocket eDGe Battery Replacement: étape 3, image 2 de 3 enTourage Pocket eDGe Battery Replacement: étape 3, image 3 de 3
    • Using the plastic opening tool, lift the back plate from both sides of your device and remove them.
  4. enTourage Pocket eDGe Battery Replacement: étape 4, image 1 de 1
    • Locate the side containing the battery. Lift the top of the battery out using your finger and the indentation at the top.
  5. enTourage Pocket eDGe Battery Replacement: étape 5, image 1 de 1
    • Carefully unplug the bottom side of the battery from the connecting plug and set the disconnected battery aside.
3 autres ont terminé cette réparation.
Adrian Do
Membre depuis le 09/24/15
355 Réputation
3 tutoriels rédigés
Équipe
University of Alabama, Team 1-3, Sydow campbell Fall 2015 Membre de l'équipe University of Alabama, Team 1-3, Sydow campbell Fall 2015
UA-SYDOW CAMPBELL-F15S1G3
4 membres
3 tutoriels rédigés
2 commentaires de tutoriel
Great tutorial! I have two of these. Does anyone know where I can buy a replacement battery? I have looked everywhere. I would retrofit if I could find one large and flat enough. 7.2v 2000mA. Hate to have to trash them but they don’t make parts anymore.
Ron - Réponse
does anyone know the pin out of the battery connector, thank you
Tony - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 22
Total : 1,582
