Introduction
If your eufy RoboVac 11 rolling brush is getting stuck, isn't rotating, or having trouble picking up debris, looking through this guide may be beneficial. Replacing the rolling brush motor requires a little more attention to detail but is reasonably straightforward. With these steps, removal will be quick and easy. Removing the rolling brush before attempting to remove the motor is essential. Attempting to remove the motor without removing the brush may result in personal injury or damage to the device. Regular cleaning for the rolling brush will help its effectiveness in picking up debris.
Ce dont vous avez besoin
Remove the nine 10 mm screws with the Phillips #1 precision screwdriver.
Remove the single 10 mm screw with the Phillips #1 screwdriver.
Remove the rolling brush.
