Aller au contenu principal
eufy RoboVac 11 Wheel and Wheel Motor Replacement
Ce dont vous avez besoin
  1. eufy RoboVac 11 Wheel and Wheel Motor Replacement, Front Cover and Motherboard: étape 1, image 1 de 2 eufy RoboVac 11 Wheel and Wheel Motor Replacement, Front Cover and Motherboard: étape 1, image 2 de 2
    • Remove the nine 10 mm screws with the Phillips #1 precision screwdriver.
    • Keep track of these screws. They are the same length as the interior screws but wider in diameter.
  2. eufy RoboVac 11 Wheel and Wheel Motor Replacement: étape 2, image 1 de 2 eufy RoboVac 11 Wheel and Wheel Motor Replacement: étape 2, image 2 de 2
    • Remove the six 7 mm screws on the bumper with the Phillips #1 screwdriver.
  3. eufy RoboVac 11 Wheel and Wheel Motor Replacement: étape 3, image 1 de 3 eufy RoboVac 11 Wheel and Wheel Motor Replacement: étape 3, image 2 de 3 eufy RoboVac 11 Wheel and Wheel Motor Replacement: étape 3, image 3 de 3
    • Remove the top plate from the body of the device.
    • Unplug the bumper from the motherboard.
  4. eufy RoboVac 11 Wheel and Wheel Motor Replacement: étape 4, image 1 de 2 eufy RoboVac 11 Wheel and Wheel Motor Replacement: étape 4, image 2 de 2
    • Remove the three 10 mm motherboard screws with a Phillips #1 screwdriver.
    • Cleaning the motherboard and inside of the device outdoors with a compressed air cleaner will help the robot last longer.
  5. eufy RoboVac 11 Wheel and Wheel Motor Replacement: étape 5, image 1 de 2 eufy RoboVac 11 Wheel and Wheel Motor Replacement: étape 5, image 2 de 2
    • Unplug the cables from the motherboard.
  6. eufy RoboVac 11 Wheel and Wheel Motor Replacement, Rolling Brush: étape 6, image 1 de 2 eufy RoboVac 11 Wheel and Wheel Motor Replacement, Rolling Brush: étape 6, image 2 de 2
    • Remove the single 10 mm screw with the Phillips #1 screwdriver.
    • Remove the rolling brush.
  7. eufy RoboVac 11 Wheel and Wheel Motor Replacement, Wheel and Wheel Motor: étape 7, image 1 de 3 eufy RoboVac 11 Wheel and Wheel Motor Replacement, Wheel and Wheel Motor: étape 7, image 2 de 3 eufy RoboVac 11 Wheel and Wheel Motor Replacement, Wheel and Wheel Motor: étape 7, image 3 de 3
    • Remove the wheels.
    • The removal of the two wheels is the same on both sides, but on the left side there is a motor in the way of the wheels.
    • Remove the single 10 mm screw with the Phillips #1 screwdriver and then pull upwards to remove the piece preventing removal.
  8. eufy RoboVac 11 Wheel and Wheel Motor Replacement: étape 8, image 1 de 3 eufy RoboVac 11 Wheel and Wheel Motor Replacement: étape 8, image 2 de 3 eufy RoboVac 11 Wheel and Wheel Motor Replacement: étape 8, image 3 de 3
    • Remove the three 10 mm screws with the Phillips #1 screwdriver.
    • Remove motors.
    • The process for removing the left and right motors is the same.
Kyleigh Hill
Membre depuis le 09/27/22
223 Réputation
2 tutoriels rédigés
Équipe
Utah Tech University, Team 1-3, McMurrin Fall 2022 Membre de l'équipe Utah Tech University, Team 1-3, McMurrin Fall 2022
UTAHTECH-MCMURRIN-F22S1G3
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 10
30 derniers jours : 49
Total : 1,291
