Introduction
If your eufy RoboVac 11 is having trouble maneuvering throughout rooms or is immobile altogether, taking a look through this guide may be beneficial. This guide requires taking apart the device, keeping track of various parts, and some skill in replacing both the wheels and motors. However, because of how in depth this guide is, it will allow you to have access to the entire interior of the device. It is a perfect time to clean it thoroughly.
Ce dont vous avez besoin
Remove the nine 10 mm screws with the Phillips #1 precision screwdriver.
Remove the single 10 mm screw with the Phillips #1 screwdriver.
Remove the rolling brush.
Remove the wheels.
Remove the single 10 mm screw with the Phillips #1 screwdriver and then pull upwards to remove the piece preventing removal.
