Aller au contenu principal
eufy Security SpaceView Monitor Battery Replacement
Ce dont vous avez besoin
  1. eufy Security SpaceView Monitor Battery Replacement, Display Assembly: étape 1, image 1 de 2 eufy Security SpaceView Monitor Battery Replacement, Display Assembly: étape 1, image 2 de 2
    • Using either the Jimmy or the IFixit Opening tool, press into the opening notches built into the lower portion of the display.
    • The sides of the display each have two notches, while the top has 3 notches, and the bottom has 4 respectively.
    • Using the given tools, ensure that the tool enters the space of the opening notches, and apply force downwards, prying that specific part up and away from the housing.
    • Repeat for all sides and notches, until the display is completely detached from the rest of the monitor.
  2. eufy Security SpaceView Monitor Battery Replacement: étape 2, image 1 de 1
    • Lift the display up and away from the housing.
    • Take care to not twist or pull on the ribbon connector.
  3. eufy Security SpaceView Monitor Battery Replacement, Screen: étape 3, image 1 de 1
    • Lay the display face down on a table, to expose the back of the screen.
    • Use Phillips #00 screwdriver to unscrew each of the six screws that hold the display in place.
    • There are two on each end of the display, and one on each of its longer sides.
  4. eufy Security SpaceView Monitor Battery Replacement: étape 4, image 1 de 2 eufy Security SpaceView Monitor Battery Replacement: étape 4, image 2 de 2
    • Gently lift the display housing, and set it aside.
    • The housing is ready to have the new display installed.
  5. eufy Security SpaceView Monitor Battery Replacement: étape 5, image 1 de 1
    • Gently disconnect the ribbon connector from the motherboard, taking care not to damage it.
  6. eufy Security SpaceView Monitor Battery Replacement, Motherboard: étape 6, image 1 de 2 eufy Security SpaceView Monitor Battery Replacement, Motherboard: étape 6, image 2 de 2
    • Using a Phillips #00 screwdriver, unscrew the 4 retaining screws in each corner of the motherboard.
  7. eufy Security SpaceView Monitor Battery Replacement: étape 7, image 1 de 3 eufy Security SpaceView Monitor Battery Replacement: étape 7, image 2 de 3 eufy Security SpaceView Monitor Battery Replacement: étape 7, image 3 de 3
    • Starting with either red/black wired connector on, gently pull it from its receptor and set it aside.
    • Pull the white ribbon connector from the motherboard, on the side closest to the battery.
    • Lift the motherboard and disconnect the antenna connector from its port.
    • The motherboard is free from the housing and can be replaced.
  8. eufy Security SpaceView Monitor Battery Replacement, Battery: étape 8, image 1 de 1
    • Using a Jimmy, place the tool behind the battery where the glue is visible.
  9. eufy Security SpaceView Monitor Battery Replacement: étape 9, image 1 de 1
    • Pry the battery from the monitor case.
Declan Andrews
Membre depuis le 10/31/23
181 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023 Membre de l'équipe UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G5
3 membres
6 tutoriels rédigés
2 commentaires
I can't find any info on suitable replacement batteries. There isn't a model number on the battery, just the following: FT804163P 2900mAh 11.02Wh BHZKF28L 3.8V. Where did you source your replacement battery from?
Trevor Graham - Réponse
I used this one from ebay (104050, 2500mAh, the 1.25mm connector version): https://www.ebay.com/itm/115814771499 referenced by this reddit comment: https://www.reddit.com/r/techsupport/com...
I had to splice and swap the red/black wires as they were in the wrong order for the spaceview, but other than that, it fit in the monitor casing and worked as expected.
spacewarp - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 53
30 derniers jours : 254
Total : 1,416
