Aller au contenu principal
eufy Security SpaceView Monitor Display Assembly
Ce dont vous avez besoin
  1. eufy Security SpaceView Monitor Display Assembly, Display Assembly: étape 1, image 1 de 2 eufy Security SpaceView Monitor Display Assembly, Display Assembly: étape 1, image 2 de 2
    • Using either the Jimmy or the IFixit Opening tool, press into the opening notches built into the lower portion of the display.
    • The sides of the display each have two notches, while the top has 3 notches, and the bottom has 4 respectively.
    • Using the given tools, ensure that the tool enters the space of the opening notches, and apply force downwards, prying that specific part up and away from the housing.
    • Repeat for all sides and notches, until the display is completely detached from the rest of the monitor.
  2. eufy Security SpaceView Monitor Display Assembly: étape 2, image 1 de 1
    • Lift the display up and away from the housing.
    • Take care to not twist or pull on the ribbon connector.
To reassemble, lay the display in its original orientation on top of the housing, and apply even force to the edges of the display. It should click each time, and securely itself tightly to the housing.
ZFarley
Membre depuis le 10/31/23
395 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023 Membre de l'équipe UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G5
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 29
Total : 147
