Aller au contenu principal
hp pavilion 15-cc023cl Motherboard Replacement
Ce dont vous avez besoin
  1. hp pavilion 15-cc023cl Motherboard Replacement, Battery: étape 1, image 1 de 2 hp pavilion 15-cc023cl Motherboard Replacement, Battery: étape 1, image 2 de 2
    • Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
  2. hp pavilion 15-cc023cl Motherboard Replacement: étape 2, image 1 de 1
    • Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Be gentle when applying force to the cover.
  3. hp pavilion 15-cc023cl Motherboard Replacement: étape 3, image 1 de 2 hp pavilion 15-cc023cl Motherboard Replacement: étape 3, image 2 de 2
    • Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
  4. hp pavilion 15-cc023cl Motherboard Replacement: étape 4, image 1 de 2 hp pavilion 15-cc023cl Motherboard Replacement: étape 4, image 2 de 2
    • Disconnect the port connecting the battery and the motherboard and then remove.
  5. hp pavilion 15-cc023cl Motherboard Replacement, Hard Drive: étape 5, image 1 de 1
    • Use a spudger to lift the latch that holds the hard drive cable in place.
  6. hp pavilion 15-cc023cl Motherboard Replacement: étape 6, image 1 de 1
    • Use a plastic opening tool to pry the hard drive out.
  7. hp pavilion 15-cc023cl Motherboard Replacement: étape 7, image 1 de 1
    • Disconnect the hard drive cable.
  8. hp pavilion 15-cc023cl Motherboard Replacement: étape 8, image 1 de 1
    • Lift the plastic wedges up on both sides of the hard drive.
  9. hp pavilion 15-cc023cl Motherboard Replacement, Motherboard: étape 9, image 1 de 1
    • Locate the motherboard.
  10. hp pavilion 15-cc023cl Motherboard Replacement: étape 10, image 1 de 2 hp pavilion 15-cc023cl Motherboard Replacement: étape 10, image 2 de 2
    • Use a PH0 screwdriver to unscrew the three 3 mm Phillips head screws located on the fan.
  11. hp pavilion 15-cc023cl Motherboard Replacement: étape 11, image 1 de 1
    • Use a PH1 screwdriver to unscrew the four 3mm Phillips head screws located on the processor cover.
    • Disconnect the cable.
  12. hp pavilion 15-cc023cl Motherboard Replacement: étape 12, image 1 de 1
    • Disconnect the plastic arm attached to the processor and remove.
    • Disconnect the cable attaching the fan to the motherboard and remove.
  13. hp pavilion 15-cc023cl Motherboard Replacement: étape 13, image 1 de 1
    • Use a PH1 screwdriver to unscrew one 3mm Phillips head screws on Wifi card.
    • Disconnect the Wifi card.
    • Be careful not to break any of the connectors.
  14. hp pavilion 15-cc023cl Motherboard Replacement: étape 14, image 1 de 3 hp pavilion 15-cc023cl Motherboard Replacement: étape 14, image 2 de 3 hp pavilion 15-cc023cl Motherboard Replacement: étape 14, image 3 de 3
    • Disconnect the 5 cables to keyboard and speakers.
    • You may have to pry some up with the spudger.
  15. hp pavilion 15-cc023cl Motherboard Replacement: étape 15, image 1 de 2 hp pavilion 15-cc023cl Motherboard Replacement: étape 15, image 2 de 2
    • Use a PH1 screwdriver to unscrew six 3 mm Phillips head screws on the motherboard.
  16. hp pavilion 15-cc023cl Motherboard Replacement: étape 16, image 1 de 1
    • Use the iFixit opening tools to pry motherboard from back of laptop.
  17. hp pavilion 15-cc023cl Motherboard Replacement: étape 17, image 1 de 1
    • Disconnect SD and USB card cable.
2 autres ont terminé cette réparation.
Stephanie Henry
Membre depuis le 10/02/18
1 077 Réputation
5 tutoriels rédigés
2 commentaires
Good job Stephany. I would’ve been lost without you…
your friend eternally,
Richey Dale
richeydale67 - Réponse
How can i get this model motherboard
Adeyinka Alasi - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 1,391
