Introduction
How to remove the hard drive and its bracket from your computer.
Ce dont vous avez besoin
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Remove the following 4 screws on the bottom of the computer:
Two 3 mm Phillips from the left side of the computer.
One 4.5 mm Phillips near the latch mechanism (this screw may be missing in 800 MHz iBooks)
One 14.2 mm Phillips near the front, right corner.
Remove the following 14 screws (some models may be missing a couple of screws):
One 2.5 mm Phillips.
Six 3.5 mm Phillips.
One 4.5 mm Phillips near the sleep light with a small shaft.
Two 4.5 mm Phillips with larger shafts.
Four 5 mm Phillips
If a screw is inserted in the left hole, the 14.2 mm screw in step 24 can not be inserted to hold the top case down.
10 autres ont terminé cette réparation.
