Aller au contenu principal
iBook G3 12" LCD Replacement
Ce dont vous avez besoin
  1. iBook G3 12" LCD Replacement, Battery: étape 1, image 1 de 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G3 12" LCD Replacement, Rear Display Bezel: étape 2, image 1 de 2 iBook G3 12" LCD Replacement, Rear Display Bezel: étape 2, image 2 de 2
    • Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
    • If you don't have a 1.5mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
  3. iBook G3 12" LCD Replacement: étape 3, image 1 de 2 iBook G3 12" LCD Replacement: étape 3, image 2 de 2
    • Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display.
    • Rotate the spudger away from the display to pry the rear bezel off the front bezel.
  4. iBook G3 12" LCD Replacement: étape 4, image 1 de 1
    • Run your spudger along the top edge of the front display bezel to evenly separate the two bezels.
  5. iBook G3 12" LCD Replacement: étape 5, image 1 de 2 iBook G3 12" LCD Replacement: étape 5, image 2 de 2
    • Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display.
  6. iBook G3 12" LCD Replacement: étape 6, image 1 de 1
    • Use the flat end of a spudger to pry the rear bezel away from the right edge of the display.
    • If necessary, pry along the bottom edge of the rear bezel to separate it from the display assembly.
  7. iBook G3 12" LCD Replacement: étape 7, image 1 de 1
    • Lift the rear bezel off the display assembly.
  8. iBook G3 12" LCD Replacement, LCD: étape 8, image 1 de 2 iBook G3 12" LCD Replacement, LCD: étape 8, image 2 de 2
    • Close the display.
    • Remove the small pieces of yellow tape securing the thin metal LCD cover to the display.
    • Remove the large piece of tape near the right display hinge.
  9. iBook G3 12" LCD Replacement: étape 9, image 1 de 2 iBook G3 12" LCD Replacement: étape 9, image 2 de 2
    • Remove the tape covering the inverter cable connector.
    • Remove the piece of foil tape near the center of the thin metal LCD cover.
  10. iBook G3 12" LCD Replacement: étape 10, image 1 de 2 iBook G3 12" LCD Replacement: étape 10, image 2 de 2
    • Remove the Phillips screw near the right display hinge.
    • Use the tip of a spudger to remove the small spacer under the screw you just removed.
  11. iBook G3 12" LCD Replacement: étape 11, image 1 de 2 iBook G3 12" LCD Replacement: étape 11, image 2 de 2
    • Pull the foil/braided pieces of tape off the aluminum frame of the clutch hinges. Leave the tape attached to the thin steel LCD cover.
    • Remove the small piece of tape holding the display data cable ground strap to the LCD cover.
  12. iBook G3 12" LCD Replacement: étape 12, image 1 de 2 iBook G3 12" LCD Replacement: étape 12, image 2 de 2
    • Remove the two Phillips screws securing the left and right sides of the LCD to the frame of the clutch hinges (four screws total).
  13. iBook G3 12" LCD Replacement: étape 13, image 1 de 1
    • Carefully remove the thin steel LCD cover.
  14. iBook G3 12" LCD Replacement: étape 14, image 1 de 2 iBook G3 12" LCD Replacement: étape 14, image 2 de 2
    • Remove the long piece of tape securing the display data cable to the LCD.
    • Disconnect the display data cable by pulling the cable away from the socket on the LCD.
  15. iBook G3 12" LCD Replacement: étape 15, image 1 de 1
    • Disconnect the backlight cable from the inverter.
    • It is helpful to use a spudger to push the backlight connector away from its socket while you lightly pull its cables away from the inverter.
  16. iBook G3 12" LCD Replacement: étape 16, image 1 de 3 iBook G3 12" LCD Replacement: étape 16, image 2 de 3 iBook G3 12" LCD Replacement: étape 16, image 3 de 3
    • Open the display.
    • Lift the LCD out of the display assembly.
12 autres ont terminé cette réparation.
Pièces jointes
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 20
Total : 11,305
