Aller au contenu principal
iBook G3 Clamshell CD Faceplate Replacement
Ce dont vous avez besoin
  1. iBook G3 Clamshell CD Faceplate Replacement, Battery: étape 1, image 1 de 1
    • Use a coin to turn both battery locking screws 90 degrees to the left.
    • Remove the battery cover.
    • Remove the battery from the computer by pulling up on the plastic tab.
  2. iBook G3 Clamshell CD Faceplate Replacement, CD Faceplate: étape 2, image 1 de 1
    • Use a straightened paperclip to manually eject the CD-ROM tray.
  3. iBook G3 Clamshell CD Faceplate Replacement: étape 3, image 1 de 1
    • Remove the single black Phillips screw from the center of the CD-ROM bezel.
  4. iBook G3 Clamshell CD Faceplate Replacement: étape 4, image 1 de 1
    • Grasp the CD-ROM bezel and rotate it upward to remove it from the drive.
6 autres ont terminé cette réparation.
Pièces jointes
iRobot
Membre depuis le 09/24/09
1 Réputation
636 tutoriels rédigés
2 commentaires
There are two small black phillips screws which ALSO need to be removed ...... on some models. Although appearing identical, these covers are "similar" but NOT interchangeable between models of CD-Rom.
John Foster - Réponse
Help I've broke my drive cover and it won't go back on how do I fix that
Mr. Yee Macinuwm - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 13
Total : 10,034
