Aller au contenu principal
iBook G4 12" 800 MHz-1.2 GHz AirPort Extreme Card Replacement
Ce dont vous avez besoin
  1. iBook G4 12" 800 MHz-1.2 GHz AirPort Extreme Card Replacement, Battery: étape 1, image 1 de 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  2. iBook G4 12" 800 MHz-1.2 GHz AirPort Extreme Card Replacement: étape 2, image 1 de 1
    • Lift the battery out of the computer.
  3. iBook G4 12" 800 MHz-1.2 GHz AirPort Extreme Card Replacement, AirPort Extreme Card: étape 3, image 1 de 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  4. iBook G4 12" 800 MHz-1.2 GHz AirPort Extreme Card Replacement: étape 4, image 1 de 1
    • Push the wire clasp away from the AirPort card and toward the display, then rotate up to free it from the RAM shield.
  5. iBook G4 12" 800 MHz-1.2 GHz AirPort Extreme Card Replacement: étape 5, image 1 de 1
    • Grasp the clear plastic tab on the AirPort card and pull toward the display.
  6. iBook G4 12" 800 MHz-1.2 GHz AirPort Extreme Card Replacement: étape 6, image 1 de 1
    • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
21 autres ont terminé cette réparation.
Pièces jointes
iRobot
Membre depuis le 09/24/09
1 Réputation
636 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 17
Total : 30,650
