Introduction
Remplacez le boîtier inférieur en plastique.
Ce dont vous avez besoin
Utilisez une pièce pour faire tourner la vis qui verrouille la batterie, de 90 degrés dans le sens des aiguilles d'une montre.
Utilisez une punaise (ou un autre outil très fin) pour retirer les patins en caoutchouc du boîtier inférieur.
I agree with tangawk: with a flathead screwdriver it was a lot easier. One have just to go deeper enough under the tab to be effective. Just be careful: the tab could jump far.
Utilisez une spatule (spudger) ou un petit tournevis à tête plate pour soulever les trois anneaux en métal qui abritaient les patins.
Retirez les trois vis Torx en utilisant un tournevis Torx T8.
These 3 screws actually use 2mm Allen (hex) heads, so try to find one of those first (they come in many metric Allen sets) before resorting to the T8 Torx.
If you save your IKEA wrenches from their steel cable "curtain rods," you will have a 2mm hex wrench or two to spare; the 2mm wrenches are used to tighten the pair of set-screws holding each end of the cable into the wall-mounting.
The three sets of metric allen wrenches I'd accumulated over the years did NOT contain that itty-bitty 2mm wrench, and I didn't want to try forcing a torx-fit.
However, when I finally thought to check, I DID have a 2mm hex "screwdriver tip" in a large "universal set" of odd magnetic screwdriver tips--one with things like hollow-pointed torx, hollow-pointed hex, pin tips (imagine a flat-bladed tip with the middle 1/3 removed)--those so-called "tamper-resistant" screw heads (no triangle points, though, for all the kids' toys made in China).
And why hadn't I thought to look in the screw driver set first thing? Because the hex 2mm was a WRENCH, not a screw with a hexagonal driver tip. Talk about limits imposed by "context" or "framing"--and age.
Poussez les bords fins du boîtier inférieur entourant le compartiment de la batterie. Il faut plier un peu le plastique pour le sortir des attaches et ensuite tirer vers le haut pour détacher ce côté du boîtier inférieur.
I need patience and I need it NOW!!!!
I killed my spudger on this step, trying to twist it in the seam to lift the cover up. I got better progress using it to pry out the gey band, surrounding the laptop. That action will release the catch grooves. Still a test of patience...good luck.
Passez une spatule le long de la jointure entre le boîtier supérieur et le boîtier inférieur à l'avant de l'ordinateur pour détacher les attaches du boîtier inférieur. Tirez le boîtier inférieur vers le haut et déplacez la spatule autant que nécessaire jusqu'à entendre trois clics distincts.
Continuez à passer la spatule le long du coin avant droit. Il y a deux attaches du côté des ports de l'ordinateur, une près du coin avant et l'autre à côté du port sortie de son.
I used a flathead screwdriver and an old credit card instead of a spudger. If using the screwdriver, be advised it may damage the case.
Wish I'd read the tip about the credit card! Made a few dents during this procedure as I didn't have a spudger. N.B. Plastic modeling tools are not suitable for this job!
Il y a trois attaches au niveau du lecteur optique que vous devez détacher avant que le boîtier inférieur sorte. Passez une spatule le long du boîtier inférieur, au-dessus de la fente du lecteur optique et déplacez-la vers l'arrière du boitier jusqu'à entendre trois clics distincts.
Une fois les parties avant et latérales du boîtier inférieur détachées, tournez l'ordinateur afin que la partie arrière soit face à vous. Tirez le boîtier inférieur vers le haut et en l'éloignant de vous jusqu'à ce que les attaches arrière se détachent.
Step 20.5: Have coffee and give yourself a pat on the back...
Pour remonter cette pièce, suivez ces instructions en sens inverse.
12 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
