Introduction
Guide specifically for 1.33 GHz models. Replacing a defective fan is pretty easy and will keep your laptop running cool.
Ce dont vous avez besoin
Use a pin (or anything you like) to remove the three rubber feet from the lower case.
Remove the following 10 screws from the bottom shield:
Six 3 mm Phillips
Three 7.5 mm Phillips
One 14 mm Phillips
Remove the 4 Phillips screws securing the fan to the metal framework.
2 autres ont terminé cette réparation.
