Introduction
Replace the screen correctly and completely. First by removing the backing plate. Then removing the electrical ribbon connections. Next, remove the camera and battery. Then Remove the screws holding the screen and the motherboard in place. Lastly remove the screen.
Start by powering off the device
  • Start by powering off the device
  • Place the device on a clean surface screen facing down
Ajouter un commentaire
Gently apply pressure to the  back of the device  where the backing case and screen  meet.
  • Gently apply pressure to the back of the device where the backing case and screen meet.
  • Use a plastic opening tool or spudger to lift and release the camera assembly ZIF tab.
  • Gently pull the ribbon cable free.
  • Remove the cameras
  • Remove the 8 .25" screws circled in red.
  • The battery is glued to the back of the screen. Gentle pry the battery off the screen. being careful not the bend the battery.
  • Remove the 10 .25" screws circled in red
  • Gently pry the screen out of its casing
  • Reassembly is the reverse of disassembly.
Nathanael Carlson
Membre depuis le 08/01/2018
183 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S1-G3, Freund Spring 2018 Membre de l'équipe IUPUI, Team S1-G3, Freund Spring 2018
IUPUI-FREUND-S18S1G3
3 membres
2 tutoriels rédigés
SOOOOO GOOD , Well done
Nathanael Carlson - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 35
