Aller au contenu principal
iDevices iGrill Power Delivery Wires and Springs Replacement
Ce dont vous avez besoin
  1. iDevices iGrill Power Delivery Wires and Springs Replacement, Power Delivery Wires and Springs: étape 1, image 1 de 1
    • Place the front screen of the device on a flat surface, this allows access to the back cover. Remove the back cover from the device to access the batteries.
  2. iDevices iGrill Power Delivery Wires and Springs Replacement: étape 2, image 1 de 1
    • Remove the batteries from the device, allowing you to access the screws necessary for removal of the back panel.
  3. iDevices iGrill Power Delivery Wires and Springs Replacement: étape 3, image 1 de 2 iDevices iGrill Power Delivery Wires and Springs Replacement: étape 3, image 2 de 2
    • Remove five black 10 mm Phillips #0 screws from the back side of the device.
    • Remove two silver-colored 5 mm Phillips screws from the left side of the internal cover.
  4. iDevices iGrill Power Delivery Wires and Springs Replacement: étape 4, image 1 de 1
    • Gently and slowly pull the back cover off of the iGrill, exposing the power cables to the motherboard.
  5. iDevices iGrill Power Delivery Wires and Springs Replacement: étape 5, image 1 de 2 iDevices iGrill Power Delivery Wires and Springs Replacement: étape 5, image 2 de 2
    • Gently pull the metal terminals to the batteries out of their plastic holders.
    • Position the metal terminals such that you will be able to pull the plastic component that holds the batteries away from the motherboard.
    • Remove the internal cover from the device.
  6. iDevices iGrill Power Delivery Wires and Springs Replacement: étape 6, image 1 de 1
    • After you have peeled back the rear plastic covering, you will have access to the motherboard.
  7. iDevices iGrill Power Delivery Wires and Springs Replacement: étape 7, image 1 de 1
    • From here, you will have access to both the metal terminals of the power transfer wires and the soldering points of the power transfer wires to the motherboard.
    • If any of these connections have been broken, repair them with a solder and soldering wire.
Kyle McElyea
Membre depuis le 02/16/16
259 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 3-4, Harley Spring 2016 Membre de l'équipe IUPUI, Team 3-4, Harley Spring 2016
IUPUI-HARLEY-S16S3G4
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 289
