Aller au contenu principal
iDevices iGrill Probe Replacement
Ce dont vous avez besoin
  1. iDevices iGrill Probe Replacement, Probes: étape 1, image 1 de 1
    • Remove the back plastic cover from the device; this should allow you access to the batteries.
  2. iDevices iGrill Probe Replacement: étape 2, image 1 de 1
    • Remove the batteries from the device.
  3. iDevices iGrill Probe Replacement: étape 3, image 1 de 2 iDevices iGrill Probe Replacement: étape 3, image 2 de 2
    • Remove five black 10 mm Phillips #0 screws from the back side of the device.
    • Remove two silver-colored 5 mm screws using a Phillips screwdriver. The screws are located on the left side of the internal cover.
    • Remove the accompanying plastic tabs under the screws.
    • Gently pull off the back cover from the device.
  4. iDevices iGrill Probe Replacement: étape 4, image 1 de 3 iDevices iGrill Probe Replacement: étape 4, image 2 de 3 iDevices iGrill Probe Replacement: étape 4, image 3 de 3
    • If you have not removed the 2 silver-colored screws; you must remove them now.
    • Remove the metal terminals from the battery slot closest you.
    • Pull the remaining metal terminals out of their slots. Position them such that when removing the internal cover they will not be caught.
    • Remove the internal cover.
  5. iDevices iGrill Probe Replacement: étape 5, image 1 de 1
    • After the internal plastic case has been removed, you will have access to the probe contacts.
    • You should then insert the probes to check their connection to the probe terminals.
  6. iDevices iGrill Probe Replacement: étape 6, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Using a pair of tweezers, bend the probe contacts back in place. The tweezers will touch the probe terminals when inserted.
Michelle Nguyen
Membre depuis le 02/16/16
204 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 3-4, Harley Spring 2016 Membre de l'équipe IUPUI, Team 3-4, Harley Spring 2016
IUPUI-HARLEY-S16S3G4
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 16
Total : 1,063
