Aller au contenu principal
iHome IBT16 Auxiliary Port Replacement
Ce dont vous avez besoin
  1. iHome IBT16 Auxiliary Port Replacement, Base Plate: étape 1, image 1 de 2 iHome IBT16 Auxiliary Port Replacement, Base Plate: étape 1, image 2 de 2
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
  2. iHome IBT16 Auxiliary Port Replacement: étape 2, image 1 de 2 iHome IBT16 Auxiliary Port Replacement: étape 2, image 2 de 2
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
  3. iHome IBT16 Auxiliary Port Replacement, Auxiliary Port: étape 3, image 1 de 2 iHome IBT16 Auxiliary Port Replacement, Auxiliary Port: étape 3, image 2 de 2
    • Using the Philips #00 screwdriver, unscrew and remove the two silver 10mm screws holding the motherboard
    • Don't misplace the screws! Keep them in a safe place while working on the device
    • Make sure to ground yourself prior to continuing at this point
  4. iHome IBT16 Auxiliary Port Replacement: étape 4, image 1 de 1
    • Using the plastic opening tool, pull the motherboard out of the casing
    • Make sure to lift it out at an angle to the back, as the plastic power switch is attached to the board and can be broken
  5. iHome IBT16 Auxiliary Port Replacement: étape 5, image 1 de 2 iHome IBT16 Auxiliary Port Replacement: étape 5, image 2 de 2
    • Desolder the 5 points holding the auxiliary port to the motherboard
    • Once complete, it's as simple as lifting the port from the board
Ryan Edwards
Membre depuis le 03/21/17
331 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G6, Botvin Spring 2017 Membre de l'équipe UMass Dartmouth, Team S3-G6, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G6
2 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 15
Total : 568
