Aller au contenu principal
iHome IH11 AC Power Adapter Replacement
Ce dont vous avez besoin
  1. iHome IH11 AC Power Adapter Replacement, Outer Case: étape 1, image 1 de 1
    • Unscrew the two 9.0 mm screws with the Phillips #1.
    • Remove the translucent bottom plastic piece.
  2. iHome IH11 AC Power Adapter Replacement: étape 2, image 1 de 2 iHome IH11 AC Power Adapter Replacement: étape 2, image 2 de 2
    • Remove the two 9.0mm screws on the back of the iHome with the Phillips #1 screwdriver.
    • Repeat the previous step for the two 9.0mm screws on the bottom.
    • Carefully slide the back cover off. There are wires attached to the back cover.
  3. iHome IH11 AC Power Adapter Replacement: étape 3, image 1 de 1
    • Remove the aluminum bracket by loosening the two nuts and removing the 8.0mm bolts with your hand.
  4. iHome IH11 AC Power Adapter Replacement, Motherboard: étape 4, image 1 de 2 iHome IH11 AC Power Adapter Replacement, Motherboard: étape 4, image 2 de 2
    • Remove the two 12.0mm screws that hold the motherboard with the Phillips #1 screwdriver.
    • Slide the motherboard gently out.
  5. iHome IH11 AC Power Adapter Replacement: étape 5, image 1 de 1
    • Remove the two 9.0 mm screws with the Phillips #1 screwdriver, then slide the circuit board for the AC adapter out.
    • Repeat the previous step by removing the two 9.0mm screws with the Phillips #1 screwdriver for the circuit board for the on/off switch.
  6. iHome IH11 AC Power Adapter Replacement: étape 6, image 1 de 2 iHome IH11 AC Power Adapter Replacement: étape 6, image 2 de 2
    • Unsolder the main connections holding the AC adapter to the circuit board.
    • Solder new adapter in same position with same connections.
2 autres ont terminé cette réparation.
Nick Knowles
Membre depuis le 04/19/13
21 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 14-9, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 773
