Aller au contenu principal
iHome IH11 Main Motherboard Replacement
Ce dont vous avez besoin
  1. iHome IH11 Main Motherboard Replacement, Outer Case: étape 1, image 1 de 1
    • Unscrew the two 9.0 mm screws with a Phillips #1 screwdriver.
    • Remove the translucent bottom case.
  2. iHome IH11 Main Motherboard Replacement: étape 2, image 1 de 2 iHome IH11 Main Motherboard Replacement: étape 2, image 2 de 2
    • Remove the two Phillips #1 9.0mm screws on the back of the iHome.
    • Repeat the previous step for the two 9.0mm screws on the bottom.
    • Carefully slide the back cover off. There are wires connected to the back cover.
  3. iHome IH11 Main Motherboard Replacement: étape 3, image 1 de 1
    • Remove the aluminum bracket by loosening the two nuts and removing the 8.0 mm bolts.
    • Pull the bracket out.
  4. iHome IH11 Main Motherboard Replacement: étape 4, image 1 de 2 iHome IH11 Main Motherboard Replacement: étape 4, image 2 de 2
    • Remove the two 12.0mm screws that hold the motherboard with a Phillips #1 screwdriver.
    • Slide the motherboard gently out.
  5. iHome IH11 Main Motherboard Replacement: étape 5, image 1 de 1
    • Solder each wire to corresponding input on the motherboard.
Courtney Steinberg
Membre depuis le 04/19/13
35 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 14-9, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 396
