Aller au contenu principal
iHome iAVS16 LCD (Display) Replacement
Ce dont vous avez besoin
  1. iHome iAVS16 LCD (Display) Replacement, Power Board: étape 1, image 1 de 3 iHome iAVS16 LCD (Display) Replacement, Power Board: étape 1, image 2 de 3 iHome iAVS16 LCD (Display) Replacement, Power Board: étape 1, image 3 de 3
    • Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
    • Lift up the bottom of the device.
    • Carefully lift the bottom of the device up as to not damage the ribbon cable connecting it.
  2. iHome iAVS16 LCD (Display) Replacement: étape 2, image 1 de 3 iHome iAVS16 LCD (Display) Replacement: étape 2, image 2 de 3 iHome iAVS16 LCD (Display) Replacement: étape 2, image 3 de 3
    • Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
    • Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
    • Lifting too quickly could damage the ribbon cable still attached.
  3. iHome iAVS16 LCD (Display) Replacement: étape 3, image 1 de 2 iHome iAVS16 LCD (Display) Replacement: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Using the tweezers, lift up on the black tab holding the ribbon cable down.
    • Carefully pull the ribbon cable back and out of the slot.
  4. iHome iAVS16 LCD (Display) Replacement: étape 4, image 1 de 3 iHome iAVS16 LCD (Display) Replacement: étape 4, image 2 de 3 iHome iAVS16 LCD (Display) Replacement: étape 4, image 3 de 3
    • Remove the two 1.7 mm Phillips #0 screws holding the power board in.
    • Carefully flip the board over.
    • Remove the red connector from its socket with a pair of tweezers.
  5. iHome iAVS16 LCD (Display) Replacement, LCD (Display): étape 5, image 1 de 3 iHome iAVS16 LCD (Display) Replacement, LCD (Display): étape 5, image 2 de 3 iHome iAVS16 LCD (Display) Replacement, LCD (Display): étape 5, image 3 de 3
    • Insert an iFixit opening tool into the lining on the front casing and pry it apart. Do this for both sides.
    • Further remove the front casing off from the device manually with your hands.
  6. iHome iAVS16 LCD (Display) Replacement: étape 6, image 1 de 1
    • Remove the four 1.7 mm Phillips #0 screws holding the LCD onto the front of the device.
  7. iHome iAVS16 LCD (Display) Replacement: étape 7, image 1 de 3 iHome iAVS16 LCD (Display) Replacement: étape 7, image 2 de 3 iHome iAVS16 LCD (Display) Replacement: étape 7, image 3 de 3
    • Carefully flip the LCD display over to expose the ribbon cable connecting it.
    • Lift the black tab holding the cable down, and carefully put it out of the socket.
Marco Sousa
Membre depuis le 10/25/19
293 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G7, O'Connell Fall 2019 Membre de l'équipe UMass Dartmouth, Team S1-G7, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G7
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 187
