Aller au contenu principal
iHome iAVS16 Wi-Fi Antenna Replacement
Ce dont vous avez besoin
  1. iHome iAVS16 Wi-Fi Antenna Replacement, Power Board: étape 1, image 1 de 3 iHome iAVS16 Wi-Fi Antenna Replacement, Power Board: étape 1, image 2 de 3 iHome iAVS16 Wi-Fi Antenna Replacement, Power Board: étape 1, image 3 de 3
    • Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
    • Lift up the bottom of the device.
    • Carefully lift the bottom of the device up as to not damage the ribbon cable connecting it.
  2. iHome iAVS16 Wi-Fi Antenna Replacement: étape 2, image 1 de 3 iHome iAVS16 Wi-Fi Antenna Replacement: étape 2, image 2 de 3 iHome iAVS16 Wi-Fi Antenna Replacement: étape 2, image 3 de 3
    • Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
    • Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
    • Lifting too quickly could damage the ribbon cable still attached.
  3. iHome iAVS16 Wi-Fi Antenna Replacement: étape 3, image 1 de 2 iHome iAVS16 Wi-Fi Antenna Replacement: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Using the tweezers, lift up on the black tab holding the ribbon cable down.
    • Carefully pull the ribbon cable back and out of the slot.
  4. iHome iAVS16 Wi-Fi Antenna Replacement: étape 4, image 1 de 3 iHome iAVS16 Wi-Fi Antenna Replacement: étape 4, image 2 de 3 iHome iAVS16 Wi-Fi Antenna Replacement: étape 4, image 3 de 3
    • Remove the two 1.7 mm Phillips #0 screws holding the power board in.
    • Carefully flip the board over.
    • Remove the red connector from its socket with a pair of tweezers.
  5. iHome iAVS16 Wi-Fi Antenna Replacement, LCD (Display): étape 5, image 1 de 3 iHome iAVS16 Wi-Fi Antenna Replacement, LCD (Display): étape 5, image 2 de 3 iHome iAVS16 Wi-Fi Antenna Replacement, LCD (Display): étape 5, image 3 de 3
    • Insert an iFixit opening tool into the lining on the front casing and pry it apart. Do this for both sides.
    • Further remove the front casing off from the device manually with your hands.
  6. iHome iAVS16 Wi-Fi Antenna Replacement: étape 6, image 1 de 1
    • Remove the four 1.7 mm Phillips #0 screws holding the LCD onto the front of the device.
  7. iHome iAVS16 Wi-Fi Antenna Replacement: étape 7, image 1 de 3 iHome iAVS16 Wi-Fi Antenna Replacement: étape 7, image 2 de 3 iHome iAVS16 Wi-Fi Antenna Replacement: étape 7, image 3 de 3
    • Carefully flip the LCD display over to expose the ribbon cable connecting it.
    • Lift the black tab holding the cable down, and carefully put it out of the socket.
  8. iHome iAVS16 Wi-Fi Antenna Replacement, Wi-Fi Antenna: étape 8, image 1 de 3 iHome iAVS16 Wi-Fi Antenna Replacement, Wi-Fi Antenna: étape 8, image 2 de 3 iHome iAVS16 Wi-Fi Antenna Replacement, Wi-Fi Antenna: étape 8, image 3 de 3
    • Using an iFixit opening tool, push the tab under the top of the device to create a gap.
    • Sometimes the top will pop off easily, and other times it will not. You may need to hold the tab up while you insert the iFixit opening tool under the top lining.
    • Insert the iFixit opening tool in the gap, and slide it across to remove the top casing.
  9. iHome iAVS16 Wi-Fi Antenna Replacement: étape 9, image 1 de 3 iHome iAVS16 Wi-Fi Antenna Replacement: étape 9, image 2 de 3 iHome iAVS16 Wi-Fi Antenna Replacement: étape 9, image 3 de 3
    • Remove the top cover of the device.
    • Remove the five 1.7 mm Phillips #0 screws on the top of the device.
  10. iHome iAVS16 Wi-Fi Antenna Replacement: étape 10, image 1 de 3 iHome iAVS16 Wi-Fi Antenna Replacement: étape 10, image 2 de 3 iHome iAVS16 Wi-Fi Antenna Replacement: étape 10, image 3 de 3
    J'achète
    • Remove the Wi-Fi antenna with tweezers.
    • You may wish to completely remove the motherboard for easier access to the Wi-Fi chip and antenna. Please refer to motherboard guide for instructions.
Marco Sousa
Membre depuis le 10/25/19
293 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G7, O'Connell Fall 2019 Membre de l'équipe UMass Dartmouth, Team S1-G7, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G7
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 16
Total : 201
