Aller au contenu principal
iHome iBT230 Motherboard Replacement
Ce dont vous avez besoin
  1. iHome iBT230 Motherboard  Replacement, Motherboard: étape 1, image 1 de 1
    • Remove the four 5.5 mm Phillips Head #00 screws from the bottom palate of the iBT230.
  2. iHome iBT230 Motherboard  Replacement: étape 2, image 1 de 2 iHome iBT230 Motherboard  Replacement: étape 2, image 2 de 2
    • Grip the top of the iBT230 by placing your thumb on the back portion, where the USB port is located. Pull up, and you should notice various different colored wires, connected to the Main Motherboard.
  3. iHome iBT230 Motherboard  Replacement: étape 3, image 1 de 3 iHome iBT230 Motherboard  Replacement: étape 3, image 2 de 3 iHome iBT230 Motherboard  Replacement: étape 3, image 3 de 3
    • Unplug the connectors from all sides of the iBT230, and unplug the wire connected to the screen.
    • Make sure to note which wire goes where, you don't want to re-solder the wires into the incorrect ports!
  4. iHome iBT230 Motherboard  Replacement: étape 4, image 1 de 2 iHome iBT230 Motherboard  Replacement: étape 4, image 2 de 2
    • On the bottom component where the green Main Motherboard is located, remove the two 5.5 mm Phillips #00 screws.
    • The old Motherboard will come free from the bottom of the iBT230.
2 autres ont terminé cette réparation.
Bilal Siddiqui
Membre depuis le 04/10/17
376 Réputation
3 tutoriels rédigés
Équipe
UW Tacoma, Team S3-G6, Liner Spring 2017 Membre de l'équipe UW Tacoma, Team S3-G6, Liner Spring 2017
UWT-LINER-S17S3G6
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 654
