Aller au contenu principal
iHome iBT84 Light Fixture Replacement
Ce dont vous avez besoin
  1. iHome iBT84 Light Fixture Replacement, Motherboard: étape 1, image 1 de 2 iHome iBT84 Light Fixture Replacement, Motherboard: étape 1, image 2 de 2
    • On the opposite side of the speaker should be a sticker, remove it with your fingers or the flat plastic iFIxit tool.
    • Use a Philip's screwdriver to take the screws out of the cover.
  2. iHome iBT84 Light Fixture Replacement: étape 2, image 1 de 2 iHome iBT84 Light Fixture Replacement: étape 2, image 2 de 2
    • Once the screws are all out, the cover should come off revealing the motherboard.
  3. iHome iBT84 Light Fixture Replacement: étape 3, image 1 de 3 iHome iBT84 Light Fixture Replacement: étape 3, image 2 de 3 iHome iBT84 Light Fixture Replacement: étape 3, image 3 de 3
    • You will notice that the triangular black volume piece is loose, make sure to take that off revealing the buttons.
    • Once that is done, the motherboard can be taken out. May require some wiggling.
    • Make sure none of the wires are damaged and that they are all connected.
  4. iHome iBT84 Light Fixture Replacement: étape 4, image 1 de 1
    • The connections shown here can be taken off by pulling on the white plastic connector piece.
    • The same can be said about the white, paper like, connectors. Pull on them gently.
    • Once all connections are apart, the motherboard is safe to be replaced.
  5. iHome iBT84 Light Fixture Replacement, Light Fixture: étape 5, image 1 de 1
    • Use the screwdriver to unscrew the screws on the left and right sides.
  6. iHome iBT84 Light Fixture Replacement: étape 6, image 1 de 1
    • Once unscrewed, use the metal spudge to lift the base of the light fixture.
  7. iHome iBT84 Light Fixture Replacement: étape 7, image 1 de 2 iHome iBT84 Light Fixture Replacement: étape 7, image 2 de 2
    • Lift the base of the light fixture out with the lights.
    • Be careful. The light fixture's can be easily bent.
  8. iHome iBT84 Light Fixture Replacement: étape 8, image 1 de 2 iHome iBT84 Light Fixture Replacement: étape 8, image 2 de 2
    • Pull gently on the individual light fixture that needs to be replaced.
    • Place new individual LED light strip.
Joshua Lopez
Membre depuis le 09/25/17
101 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 595
