Aller au contenu principal
iHome iH27B Main Motherboard Replacement
Ce dont vous avez besoin
  1. iHome iH27B Main Motherboard Replacement, Outer Case: étape 1, image 1 de 1
    • Remove any iPod or apple music device connected to the iHome and unplug from any power source.
    • Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
  2. iHome iH27B Main Motherboard Replacement: étape 2, image 1 de 3 iHome iH27B Main Motherboard Replacement: étape 2, image 2 de 3 iHome iH27B Main Motherboard Replacement: étape 2, image 3 de 3
    • Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
    • Remove the plastic slide from its location and set it aside.
    • These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
    • Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
    • Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
    • Set the plastic covering and the watch battery aside.
  3. iHome iH27B Main Motherboard Replacement: étape 3, image 1 de 1
    • Remove the following screws:
    • Eight 10 mm using the Phillips #0 on the bottom of your device.
    • Cataloging each screw by size in plastic bags or separate places on a flat surface will make them easier to find when reassembling.
  4. iHome iH27B Main Motherboard Replacement: étape 4, image 1 de 1
    • Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
    • Be careful not to pry too hard. Cracking the plastic connections could make reassembly harder.
  5. iHome iH27B Main Motherboard Replacement: étape 5, image 1 de 1
    • Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
    • You should have visible access to most of the components inside the iHome now.
  6. iHome iH27B Main Motherboard Replacement, AV circuit board: étape 6, image 1 de 1
    • Two 10 mm Phillips #0
  7. iHome iH27B Main Motherboard Replacement: étape 7, image 1 de 1
    • Pull out the AV circuit board and lift it up and out of the way to allow access to other components.
  8. iHome iH27B Main Motherboard Replacement, Main Motherboard: étape 8, image 1 de 1
    • Pull the speakers away and set them aside for now. They should still be connected to the rest of the iHome by two wires.
  9. iHome iH27B Main Motherboard Replacement: étape 9, image 1 de 1
    • Remove the following 6 screws:
    • Two 7 mm Phillips #0
    • Three 10 mm Phillips #2
    • One 9 mm Phillips #2
    • Set the screws aside, careful to not mix them up with your other screws.
John Kraemer
Membre depuis le 10/09/12
76 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 3-21, Amido Fall 2012 Membre de l'équipe Cal Poly, Team 3-21, Amido Fall 2012
CPSU-AMIDO-F12S3G21
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 12
Total : 861
