Aller au contenu principal
iHome iH5 Charging Dock Replacement
Ce dont vous avez besoin
  1. iHome iH5 Charging Dock Replacement, Charging Dock: étape 1, image 1 de 1
    • Remove the eight 5/16 inch screws with a #2 Phillips screwdriver.
  2. iHome iH5 Charging Dock Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to unplug the three wires connected to the circuit board. If the wires are tight pliers might work better.
  3. iHome iH5 Charging Dock Replacement: étape 3, image 1 de 1
    • Remove the five 5/16 inch screws from the circuit board.
  4. iHome iH5 Charging Dock Replacement: étape 4, image 1 de 2 iHome iH5 Charging Dock Replacement: étape 4, image 2 de 2
    • Flip the circuit board over.
    • There are capacitors all over the back side of the board. Be careful not to touch these capacitors (blue cylinders) as they can discharge—giving you a shock.
    • Unplug the eight wires attached to the circuit board with tweezers. If the wires are tight pliers might work better.
    • There is on wire in the orange box.
    • There are two wires in the yellow box.
    • There are five wires in the green box.
  5. iHome iH5 Charging Dock Replacement: étape 5, image 1 de 1
    • Remove the following four screws securing the iHome iH5 charging dock.
    • Use a #2 Phillips screwdriver to remove the four screws.
  6. iHome iH5 Charging Dock Replacement: étape 6, image 1 de 1
    • Gently remove the charging dock from the iHome iH5 by pulling it up.
  7. iHome iH5 Charging Dock Replacement: étape 7, image 1 de 1
    • Remove the final screws connecting the iH5 charging dock to the plastic holding platform
    • Use a #2 Phillips screwdriver to remove the 3/8 inch screws.
  8. iHome iH5 Charging Dock Replacement: étape 8, image 1 de 1
    • Replace the old iH5 charging dock with new iH5 charging dock.
Dustin Lamb
Membre depuis le 03/13/14
103 Réputation
1 tutoriel rédigé
Équipe
New Mexico State, Team 1-6, Easley Spring 2014 Membre de l'équipe New Mexico State, Team 1-6, Easley Spring 2014
NMSU-EASLEY-S14S1G6
5 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 979
