Aller au contenu principal
iHome iH5 Dials Replacement
Ce dont vous avez besoin
  1. iHome iH5 Dials Replacement, Dials: étape 1, image 1 de 1
    • Remove the eight screws from the bottom side of the iHome.
  2. iHome iH5 Dials Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Remove the cover to expose the inside.
    • With pliers, or tweezers,if needed, remove the three wire harnesses by gently pulling straight up on them.
  3. iHome iH5 Dials Replacement: étape 3, image 1 de 1
    • Remove the 5 screws with a #2 Phillips screwdriver.
  4. iHome iH5 Dials Replacement: étape 4, image 1 de 1
    • Remove all wire harnesses from the bottom of the board. There eight wire harnesses.
    • There are capacitors all over the back side of the board. Be careful not to touch these capacitors (blue cylinders) as they can discharge—giving you a shock.
  5. iHome iH5 Dials Replacement: étape 5, image 1 de 3 iHome iH5 Dials Replacement: étape 5, image 2 de 3 iHome iH5 Dials Replacement: étape 5, image 3 de 3
    • Remove the two screws from the speakers with a #2 Phillips screwdriver.
    • Turn the device on its front side and remove the two screws with a #2 Phillips screwdriver.
    • Pull the speaker up from the back as shown with the speaker on the right. Then pull the speaker straight back as shown with the speaker on the left.
  6. iHome iH5 Dials Replacement: étape 6, image 1 de 1
    • Remove the front piece by pulling up until it hits the plastic pieces sticking out from the display screen. Then pull it out horizontally from the device.
  7. iHome iH5 Dials Replacement: étape 7, image 1 de 1
    • Remove the three screw from the dial with a #2 Phillips screwdriver.
  8. iHome iH5 Dials Replacement: étape 8, image 1 de 1
    • Pull back the circuit board to access the plastic piece.
    • Lift to separate the plastic piece from the dial.
    • Replace the broken piece.
3 autres ont terminé cette réparation.
Maggie Hill
Membre depuis le 03/20/14
379 Réputation
3 tutoriels rédigés
Équipe
New Mexico State, Team 1-6, Easley Spring 2014 Membre de l'équipe New Mexico State, Team 1-6, Easley Spring 2014
NMSU-EASLEY-S14S1G6
5 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 1,046
