Introduction
You will need to take completely apart the device to reach the underside of the dock.
This replacement is best done on a flat surface with plenty of room to work. Opening up the iHome involves the removal of many different screws. It is important to keep track of these screws! You can do this by placing the screws on a magnetic mat in the order of removal. This allows for easy reassembly.
Ce dont vous avez besoin
Pull the tab towards you and lift up to remove the battery cover.
Remove the two AA batteries.
Unscrew the four 8mm Phillips #2 screws.
Unscrew the six 25mm Phillips #2 screws.
Reinstall the backup battery cover so it is out of the way.
Place the upper housing upside down.
Remove the one 3mm Phillips #0 screw.
Remove the two 6 mm Philips #0 screws.
