Aller au contenu principal
iHome iP1 Motherboard Replacement
Ce dont vous avez besoin
  1. iHome iP1 Motherboard Replacement, Back Cover: étape 1, image 1 de 1
    • Orient the iHome upside down with the speakers facing away from you.
  2. iHome iP1 Motherboard Replacement: étape 2, image 1 de 2 iHome iP1 Motherboard Replacement: étape 2, image 2 de 2
    • Remove the four 9.5 mm Phillips #2 screws located on each of the four corners of the iHome's back cover.
  3. iHome iP1 Motherboard Replacement: étape 3, image 1 de 1
    • Remove the back cover by grabbing its sides and lifting it off the iHome.
  4. iHome iP1 Motherboard Replacement, Motherboard: étape 4, image 1 de 2 iHome iP1 Motherboard Replacement, Motherboard: étape 4, image 2 de 2
    • Disconnect all five wire bundles attached to the motherboard by pulling them away from their connection.
    • The order in which the wire bundles are removed does not matter.
    • You may need to remove some black foam tape in order fully disconnect some of the wires.
  5. iHome iP1 Motherboard Replacement: étape 5, image 1 de 2 iHome iP1 Motherboard Replacement: étape 5, image 2 de 2
    • Unscrew the four 9.5 mm Phillips #2 screws on the four metal brackets located at each corner of the motherboard.
  6. iHome iP1 Motherboard Replacement: étape 6, image 1 de 2 iHome iP1 Motherboard Replacement: étape 6, image 2 de 2
    • Unscrew the grey 6.0 mm Phillips #1 screw directly above the red, blue, and green component ports.
  7. iHome iP1 Motherboard Replacement: étape 7, image 1 de 3 iHome iP1 Motherboard Replacement: étape 7, image 2 de 3 iHome iP1 Motherboard Replacement: étape 7, image 3 de 3
    • Remove the motherboard from its housing by grabbing it near its edges and carefully pulling it upward.
3 autres ont terminé cette réparation.
Sachin Shenoi
Membre depuis le 10/10/16
333 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 20-1, Livingston Fall 2016 Membre de l'équipe Cal Poly, Team 20-1, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G1
4 membres
7 tutoriels rédigés
5 commentaires
Easy to do,
but where can i buy a new motherboard ?
reagrds
Joerg (ifixit@xyz.logopainter.de)
Joerg Peters - Réponse
I have the same problem ? Where I can obtain a new motherboard ?
Stefano Antoniutti
anto5657@alice.it
Stefano Antoniutti - Réponse
Were you able to buy the motherboard?
Rodrigo -
Rodrigo
rodrigo@r7criacoes.com.br
Rodrigo - Réponse
i also facing same issue, where can i get new motherboard ?
riyupc123@gmail.com
Riyu PC - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 20
Total : 1,749
