Aller au contenu principal
iHome iP21 Motherboard Replacement
Ce dont vous avez besoin
  1. iHome iP21 Motherboard Replacement, Base: étape 1, image 1 de 3 iHome iP21 Motherboard Replacement, Base: étape 1, image 2 de 3 iHome iP21 Motherboard Replacement, Base: étape 1, image 3 de 3
    • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
    • Unscrew the four 11mm screws from the base.
    • Pry the base loose using the spudger.
    • Remove the base by hand.
  2. iHome iP21 Motherboard Replacement, Housing: étape 2, image 1 de 2 iHome iP21 Motherboard Replacement, Housing: étape 2, image 2 de 2
    • Remove the two black 6mm screws connecting the main circuit board to the housing top.
    • Gently pull front housing from the back housing.
  3. iHome iP21 Motherboard Replacement, Circuit board: étape 3, image 1 de 1
    • Follow the prerequisite guide to remove the main housing.
  4. iHome iP21 Motherboard Replacement, Circuit board mount: étape 4, image 1 de 1
    • Remove the two 7mm screws from the circuit board
  5. iHome iP21 Motherboard Replacement, Mounting Bracket: étape 5, image 1 de 1
    • Remove the three 6mm screws to detach the circuit board from metal mounting bracket.
  6. iHome iP21 Motherboard Replacement, Cables: étape 6, image 1 de 3 iHome iP21 Motherboard Replacement, Cables: étape 6, image 2 de 3 iHome iP21 Motherboard Replacement, Cables: étape 6, image 3 de 3
    • Peel the glue from each of the three ribbon cable connections.
    • Remove the solder joints from the back of each ribbon cable.
    • Remove the ground wires by removing the solder joints on the back of the housing.
  7. iHome iP21 Motherboard Replacement, Detach cables from circuit board: étape 7, image 1 de 3 iHome iP21 Motherboard Replacement, Detach cables from circuit board: étape 7, image 2 de 3 iHome iP21 Motherboard Replacement, Detach cables from circuit board: étape 7, image 3 de 3
    • Remove glue from 3 ribbon cables from circuit board using fingers
    • Detach speaker cables from circuit board with soldering iron
    • Remove 3 ribbon cables with soldering iron
Brandy
Membre depuis le 10/27/14
601 Réputation
6 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 8
Total : 270
