Aller au contenu principal
iHome iP21 Speaker Replacement
Ce dont vous avez besoin
  1. iHome iP21 Speaker Replacement, Base: étape 1, image 1 de 3 iHome iP21 Speaker Replacement, Base: étape 1, image 2 de 3 iHome iP21 Speaker Replacement, Base: étape 1, image 3 de 3
    • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
    • Unscrew the four 11mm screws from the base.
    • Pry the base loose using the spudger.
    • Remove the base by hand.
  2. iHome iP21 Speaker Replacement, Housing: étape 2, image 1 de 2 iHome iP21 Speaker Replacement, Housing: étape 2, image 2 de 2
    • Remove the two black 6mm screws connecting the main circuit board to the housing top.
    • Gently pull front housing from the back housing.
  3. iHome iP21 Speaker Replacement, Remove Speaker Assembly: étape 3, image 1 de 1
    • Remove two 9mm screws holding speaker assembly in iP21, using iFixit Phillips #2 bit
  4. iHome iP21 Speaker Replacement, Remove speaker from speaker assembly: étape 4, image 1 de 2 iHome iP21 Speaker Replacement, Remove speaker from speaker assembly: étape 4, image 2 de 2
    • Lift speaker assembly
    • Remove four 7mm screws to detach speaker from speaker assembly
Brandy
Membre depuis le 10/27/14
601 Réputation
6 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 205
