Aller au contenu principal
iHome iW1 Speaker Charging Nodes Replacement
Ce dont vous avez besoin
  1. iHome iW1 Speaker Charging Nodes Replacement, Battery: étape 1, image 1 de 3 iHome iW1 Speaker Charging Nodes Replacement, Battery: étape 1, image 2 de 3 iHome iW1 Speaker Charging Nodes Replacement, Battery: étape 1, image 3 de 3
    • Remove the rubber from the bottom of the speaker, use a medium blue plastic spudger to gently work its way under the rubber and slowly peel off for each of the three feet. The order does not matter.
  2. iHome iW1 Speaker Charging Nodes Replacement: étape 2, image 1 de 2 iHome iW1 Speaker Charging Nodes Replacement: étape 2, image 2 de 2
    • Remove the six 11 mm Philips #1 screws found underneath the foam to remove the steel outer metal frame.
    • Once the screws come off, keep them safely off to the side.
  3. iHome iW1 Speaker Charging Nodes Replacement: étape 3, image 1 de 2 iHome iW1 Speaker Charging Nodes Replacement: étape 3, image 2 de 2
    • Remove the metal frame gently and set aside.
  4. iHome iW1 Speaker Charging Nodes Replacement: étape 4, image 1 de 2 iHome iW1 Speaker Charging Nodes Replacement: étape 4, image 2 de 2
    • Remove the two remaining 11 mm Philips #1 screws holding the base and set them aside.
  5. iHome iW1 Speaker Charging Nodes Replacement: étape 5, image 1 de 3 iHome iW1 Speaker Charging Nodes Replacement: étape 5, image 2 de 3 iHome iW1 Speaker Charging Nodes Replacement: étape 5, image 3 de 3
    • Lift the base up gently keeping in mind that the base is connected with wires to internal parts of the speaker.
    • Disconnect the white bundled cable connector attached to the charging node using a spudger. The base of the speaker is now free to be removed.
  6. iHome iW1 Speaker Charging Nodes Replacement: étape 6, image 1 de 3 iHome iW1 Speaker Charging Nodes Replacement: étape 6, image 2 de 3 iHome iW1 Speaker Charging Nodes Replacement: étape 6, image 3 de 3
    • Remove the white power cable connector that connects the charging node to the battery, using the plastic spudger.
    • Pry the battery off using the plastic spudger.
  7. iHome iW1 Speaker Charging Nodes Replacement, Charging Nodes: étape 7, image 1 de 3 iHome iW1 Speaker Charging Nodes Replacement, Charging Nodes: étape 7, image 2 de 3 iHome iW1 Speaker Charging Nodes Replacement, Charging Nodes: étape 7, image 3 de 3
    • Unscrew the two 11 mm Philips #1 screws on the charging nodes.
    • Remove the charging node from the speaker and set aside.
Victor Germino
Membre depuis le 02/14/17
828 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team 20-6, Remmell Spring 2017 Membre de l'équipe USF Tampa, Team 20-6, Remmell Spring 2017
USFT-REMMELL-S17S20G6
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 885
